#61
I can remember back in 1979 my 69 Camaro did the same thing. Then in 1986 my 68 Firebird did it too. I think it's normal because I know my 69 Camaro and 68 Firebird were both totally original. The Camaro only had 26000 miles on it. |
#62
Idk man, like I said Im just going to put it back together with the new parts when I get them and see what happens. Im really hoping its not something stupid like the fuel pump concentric being bad or something. Or some miniscule detail in the lines that I basically have to rip them all out to find.
#63
1967 GTO, 467 roller motor, e heads ported, tremec T56 magnum 6 speed and 9" done. EZ EFI 2.0 with FAST dual sync distributor and separate nitrous system done. Track is at 4300 ft elevation. so far a best of 11.95@116. Suspension now getting dialed in...tubular front a arms with dual adjustable coil overs HR Parts n stuff rear bar and whole car lowered 3 inches.. |
#64
the rollover vent comes in 2 types, the one i have is a remote mount that i connected to the return line of the robbmc pickup with a ~6" hose to mount higher than the tank inlet to relieve pressure. they make a in tank mount vent too but would require dropping the tank. best bet for now might be to just drill the cap. heres a link to their vents. http://www.tanksinc.com/index.cfm/pa...cat/cat167.htm |
#65
Pokey is right about the A-bodies. Before 1970 some of them had a vent system that went up into the trunk under the trunk latch. My fathers 69 GTO has one of these vent systems. His car also came factory equipped with a return style fuel system as well which I don't see on every 69 model. Just an FYI, when we converted it to the Tanks Inc setup and an internal electric fuel pump, the vent system Tanks Inc sent along didn't work all that well. Basically a check valve that you are supposed to mount as high as you can. So mounting it as high as physically possible which is above the rearend, the highest point of the floor, is still barely higher than the top of the gas tank. This proved to not be enough and filling the tank, along with tank pressure, would push gas right out of that vent and leak all over the place. I ended up modifying the tank and converting it back to the stock 69 vent system that goes up into the trunk. No more issues. |
#66
FUEL TANK GAS CAPS ARE DESIGNED TO ALLOW ATMOSPHERIC PRESSURE TO ENTER THE TANK, not let pressure out. If you did not allow the atmospheric pressure to enter the tank you would not have any fuel flow. The Tank would be in a vacuum. NOT GOOD.
At one time I did Emissions Calibration and Testing for EPA and CARB certification. I used to have a full sized (at one time) Gas Tank that was the size of a Kleenex Box (because the technician did not remove the fuel cap and the POWERFUL Fuel Suction Pump (used to drain the track fuel from the tank) sucked the tank down to the Kleenex Box size. Finally threw that tank away. A typical mechanical fuel pump can create a small depression in the tank but is really counting on the atmospheric pressure (air) flowing thru the vent line or Carbon Canister to pressurize the fuel in the tank and send it forward to the engine. So gas caps do not vent outward, they vent inward. The fuel tanks with multiple vents went to a vent manifold behind the seat and then to the carbon canister. The multiple lines were there so at least one vent line was open no matter what the position of the vehicle/tank was. I have attached a couple of the Pontiac actual Vent Tube pictures (1966 and 1968). Here is a link to more info on the vent tubes for Pontiac. https://www.gtoforum.com/f154/gas-tank-vent-93353/ The Tanks inc Roll-over Valves seem to have a couple of different designs.
"Engineers do stuff for reasons" Tom Vaught Despite small distractions, there are those who will go Forward, Learning, Sharing Knowledge, Doing what they can to help others move forward. Last edited by Tom Vaught; 07-16-2019 at 10:09 AM. |
#68
Now you are in my wheelhouse. That was only on 400 cars. It's one of the ways to doc a true one. Just like the pitman arm on a true 69 Z. Priceless info for a collector. Not many know and you catch it with clones.
#69
so drilling a hole would only be a benefit if your cap doesnt vent inwards, according to tomV there is no need for a outwards pressure vent... there will be some slight pressure on hot days or as fuel heats up, but its not enough to be dangerous & explode the tank, im sure the engineers factored the pressure into the design of the tank. tom v- so are you saying there needs to be some pressure in the tank to help fuel supply? i have a rollover vent on mine since i wanted to aleviate the slight pressure build up i got on hot days. im fine removing the cap slowly to release any pressure if the positive pressure will help fuel delivery, or at least not hurt it. edit: i just tried to blow through the cap untill i was red faced & almost saw stars! & it does not vent out at all. even hit it with a air hose at about 50psi & no outward venting. |
#70
I had a experience a couple years ago with my 69 bird.Vented cap,no return line and non vented tank.Carb was a 3310 holley.My garage faces west and gets very hot in the afternoon sun.Went out to drive the bird,tried to start and the engine was locked up.Could not figure out what was going on.Finally pulled the plugs,cranked it over and it shot raw gas all over the engine compartment.The fuel vapors had expanded and pushed fuel past the needle and seats and filled a couple cyc with fuel.It was a factory 366 NASCAR V engine.Thank God it did not light and stuff a rod through the rare block.I drive the car with the vented cap but have another cap with a small hole drilled in it when the car is in the garage.FWIW,Tom
#71
http://www.tanksinc.com/index.cfm/pa...prod/prd98.htm I was actually looking to see if I could drill out the center of a cap and add one of those bulkhead style vents in the cap, but I don't think there is enough room.
#72
I have a repro tank which is probably based on a Camaro. I may get aggressive and drop it since I don't have a functioning fuel system to drive it anyway. I just don't want to deal with draining it. But I may inspect to see if there is easy room to add a bulkhead fitting and a remove vent.
My cap I did blow out not knowing any better and air did escape when you applied enough pressure, so maybe that's the problem. Again, its hard to say when I cant troubleshoot since the pump isn't in it. Mine for sure used to hold some pressure on hot days and recently it hasn't. I'll see if air moves from the other way when I get home. That said maybe it was clogged and a removed the obstruction when I blew in it last night. Its all conjecture until I get the pump back and can see whats up.
1967 Firebird 462 580hp/590ftlbs 1962 Pontiac Catalina Safari Swapped in Turd of an Olds 455 Owner/Creator Catfish Motorsports https://www.youtube.com/@CatfishMotorsports Last edited by RocktimusPryme; 07-16-2019 at 10:44 AM. |
#73
Mine cap I did blow out not knowing any better and air did escape when you applied enough pressure, so maybe that's the problem. Again, its hard to say when I cant troubleshoot since the pump isn't in it.
#74
Those Tanks Inc vents are junk, spray fuel all over the place, but technically, they work. Anything over a half a tank, if you slam on the brakes, it pours out the vent, and it does make the garage smell.
As Tom mentioned, 71-up got the fuel separator which is mounted in the trunk behind the rear seat upright. It doesn't care if it gets a big splash of fuel, it will drain right back into the tank. The charcoal canister is basically just to help remove vapor/smell. The canister also has a line that goes to a vacuum fitting on the carb, so heavy vapor gets sucked in and burned. IMO the vented caps are not enough, certainly not for an electric pump/return system. You will suck the tank flat. The vented cap on a deadhead system I guess would be acceptable, but it is possible that pressurized fuel could get pushed past the mech pump. And, in a high HP app, the cap may not vent enough, causing a low fuel psi/lean condition. Caps can go bad any time, and as you start creeping up on making more power, the venting can be a root cause of poor delivery. It may not be immediate, but you start dialing a combo in, and each step make 10-15 more hp for example, it will nose over at a point well beyond where it should be before you notice. For that and other reasons, I still say the 'true' solution is a return system, electric pump, and a properly vented tank. Nice thing about when you plan a performance fuel system and install it, you never have to worry about it again (for the most part). No question if it's going to deliver enough, etc, you KNOW it's right. .
#76
no reason you cant run a T at the vent line & hook this up, thats where mine is at, then i ran it up the wall of the hump area in front of the gas tank so its higher than the fuel inlet. if you think you need to vent pressure then its worth a try. im curious what tom v says about pressure in the tank, if its a benefit then i dont think you need to mess with it, just deal with the slight pressure when its hot. & by pressure in the tank i mean a minimal amount, not enough to force fuel past the carbs needle/seat. before i added the remote vent i would get some pressure when removing the cap, but never pushed past the needle/seat. Last edited by 78w72; 07-16-2019 at 12:54 PM. |
#77
just stating my experience with it, i drive this car pretty hard on the street as well as hard stops at the track running low 11's @ 121+mph with at least 3/4 tank, sometimes full & never had any fuel leak or spray out of it. |
#78
So even though this new setup I'm doing on a 72 bird does look like a different vent design then previously, because of past experience I'm just not going to use it. I decided to modify the tank, added the necessary nipples to hook up the factory evap system so the tank will vent through the charcoal canister as intended. If I find it's necessary to add more venting I might experiment with the new style Tanks Inc vent valve and see how it does, but only as a last resort. |
#79
on a 72 bird, they dont use a charcoal canister for the EEC, its just a metal box mounted behind the rear seat that doesn't have any charcoal in it. for whatever reason i eliminated that & went to a non vented 1970 tank, probably because it was a cleaner install without all the hoses going in & out. i saved it all though & may consider going back to a 1972 tank if i end up converting to a in tank pump down the road if i cant make my mechanical set up work better at the track. |
#80
Yep, 72 has what I call the charcoal canister, what is actually the plastic tank mounted on the core support with a vacuum switch on top that opens and closes the vent, as well as the metal canister you described behind the rear seat.
My 70 is kind of the opposite, it has the plastic charcoal canister tank with a vacuum switch, and a couple of extra lines that run back to the tank for venting, but it doesn't have the metal tank behind the seat. |
Thread Tools | |
Display Modes | |
