I have standard 67 gto with base 335 hp engine with stock manifolds. I am considering buying a 2.5" Flowmaster American Thunder exhaust system. Specs say install on headers on back. What do I need to do to attach to my stock manifolds. Car is automatic and has stock 2" pipes.
[This message has been edited by bus15241 (edited 10-22-2001).] |
I would strongly consider getting an exhaust system that is designed to mate to the stock manifolds. The other choice is to get a set of headers.
The only other alternative I can think of involves having someone custom bend manifold pipes to meet up at the header junction on the flowmaster system, which would be a royal pain and hard to find a shop that would do that. Since there are bolt in, manifold to tailpipe systems available, going with one of these is your best bet. |
Any good exhaust system suggestions to match up with my factory manifolds?
Do like I did.
Check for local shops that will mandrel-bend Aluminized pipe. Have the fella make the headpipes from 2.5" aluminized pipe. Have the headpipes welded to the muffler inlets if you like. Cost-effective and will last very long rust-free.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
All the exhausts I have ever had have been custom bent by an exhaust shop to fit, usually around 300 bucks for aluminized, which is a tad more expensive than ordering a kit, but better quality than the cheaper kits and it will fit better. Make sure you specify very specifically that you want 2.5" pipe.
I unfortunately do not have experience to recommend a do it yourself kit, other than noting seeing them in resto catalogues and speed shop catalogues. |
Try Torque Technologies in Georgia. They have headpipes to fit HO manifolds and custom fit 2.5 and 3 inch exhaust systems. Mandrel bent and aluminized. They may have headpipes for standard manifolds as well.
