Old 12-09-2023, 02:49 PM
T.Weber's Avatar
T.Weber T.Weber is online now
Default Using graphite spray on exhaust manifolds
I was wondering if anyone has tried using graphite spray on their exhaust manifolds? I saw it used on a couple of youtube videos, thought it looked good so I gave it a try and really liked the results. It's a couple of shades darker than as cast - cast iron but looks good enough for me. Not to mention there's no need to bead or sand blast them before using. Just wire brush, clean with Brake Cleaner, spray with Graphite spray lube, let dry & wipe down. (I used PB Blaster Graphite Dry Lubricant $6.58 at Home Depot) one 5.5 oz can easily did both exhaust manifolds. My motor is still out of the car so I can't say how well it will hold up.
Off the car - wire brush, clean & spray, let dry wipe down & install
https://www.youtube.com/watch?v=5nt75-4bzI8&t=48s
New cast iron manifold castings
https://www.youtube.com/watch?v=Qqh22Pafzag&t=344s
Old manifolds done on the car.
https://www.youtube.com/watch?v=hHXm5Hxijw4&t=189s
My manifolds I did - the as cast Master Cylinder is there for color comparison. Any comments good & bad are appreciated. Be honest - you can't hurt my feelings - I don't have any.
ID:	624715   Click image for larger version
ID:	624716   Click image for larger version
Old 12-09-2023, 03:50 PM
Shiny Shiny is offline
I like it. Nice job!
I used something similar about 15 yrs ago.....was a paste as I recall.
I don't know how well it will protect against corrosion long term (probably not great), but it's easy to touch up and I like the look better than paint and way better than rusty iron.
Old 12-09-2023, 04:03 PM
Stuart's Avatar
Stuart Stuart is offline
Kind of like the old school method of using wood stove polish, which has graphite as the main ingredient.
Old 12-09-2023, 04:05 PM
The jury’s out until you’ve put some miles on them.
Anything you paint onto exhaust manifolds or headers will look good before you run them
Hopefully they’ll look good after a few years, if not then it’s just some labor to get them off and a small outlay for a different product to get them redone.
Old 12-09-2023, 04:48 PM
tjs72lemans tjs72lemans is offline
I used the paint by brush method with the Eastwood can paint. 2500 miles later, they look as good as day I did them.
Old 12-09-2023, 06:00 PM
bluejudge bluejudge is offline
That might have been Calyx?
Old 12-09-2023, 06:19 PM
Yes, that sounds like the product. Thank you.
Old 12-09-2023, 10:39 PM
Stuart's Avatar
One benefit of using products like graphite/Calyx/stove polish/etc. is that if and when the manifolds start looking scruffy, you can just reapply more. No real preparation is needed.
Old 12-10-2023, 01:24 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by tjs72lemans View Post
I used the paint by brush method with the Eastwood can paint...
Which Eastwood product?
Old 12-10-2023, 01:43 AM
Stuart's Avatar
It appears Eastwood only has one high temp coating for exhausts these days: https://www.eastwood.com/paints/hi-t...st-paints.html Years ago they had a product with stainless steel in it that left an as cast look. I used it on my car with good results but it's not in their catalog anymore.
Old 12-10-2023, 05:45 AM
dataway's Avatar
dataway dataway is online now
I think people have been using "Slip Plate" graphite products for a while now on exhaust manifolds. They make an aerosol and a brush on. I've used it for years on my snow thrower chute. No idea how it holds up on exhaust though.
Old 12-10-2023, 10:17 AM
78w72 78w72 is offline
The makers of POR-15 have the same type of high heat manifold coating too. I used it on turbo exhaust manifolds and wastegate thats lasted for 10+ years. Looks like fresh cast iron.
Old 12-12-2023, 06:35 PM
I just looked since it's been a few years. Yes, it's POR 15. Great stuff.
The Following User Says Thank You to tjs72lemans For This Useful Post:
Old 12-12-2023, 10:27 PM
gtospieg gtospieg is offline
I used POR 15's exhaust manifold paint(followed all the instructions) and it started flaking off almost immediately. The RA manifolds were brand new at the time.
Old 12-13-2023, 10:35 AM
Strange for that to happen, must have been an issue with the prep or application or maybe a defective can. Never heard of POR high temp flaking off "immediately"... mine & everyone I know of thats used it has lasted for years, mine is at 12-13 years on turbo cast iron manifolds & wastegate with only some light signs of rust stains coming through in a few areas after all that time.
VHT spray can is supposed to be pretty good too, I knew a guy with an olds or buick at the drag strip with the blue VHT paint on headers, he came to the track for 3-4 years and we had a rivalry racing each other, it ran low 11's... the headers looked great every year I saw them, the car was street driven and did lots of runs at the track. I plan to try it when I do a clean up & repaint of the engine in my 78 that has the silver color POR header paint flaking off after about 15 years, easier to clean & mask them off than removing to recoat.
Old 12-13-2023, 08:03 PM
tstroud tstroud is offline
I’ve had both results with POR15 manifold paint.
Twice I did a set of SBC rams horn manifolds. They were sandblasted, handled with rubber gloves, washed with lacquer thinner and painted with a brush. Then left to dry for a couple days. Both times they flaked off and rusted in less than a year.
I also did a set of RARE ram air manifolds with the same procedure except I baked them in an old electric oven. They are holding up great so far 4 years later. They only have about 1000 miles on them now so time will tell.
Old 12-13-2023, 08:18 PM
I wonder if the silver color of the VHT paint that I used and baked in an industrial oven, according to their instructions, was the problem when I used it? My manifolds surface rusted just sitting outside at my painters for a couple of months.
Old 12-13-2023, 08:51 PM
How mine looked after 30k miles and 5 years of daily driver use, my first attempt at using POR-15 manifold paint about 24 years ago.
I did use Metal Prep after bead blasting them to clean and etch the bare metal before brushing on the paint. I didn’t bake them before running them on the engine. The manifolds were brand new.
ID:	624911   Click image for larger version
The Following 2 Users Say Thank You to b-man For This Useful Post:
Old 12-14-2023, 02:22 AM
The silver color VHT on my lakester's zoomies has held up quite well. They still look almost as good as they did new (in the picture).
The Following User Says Thank You to Jack Gifford For This Useful Post:
Old 12-14-2023, 03:30 AM
I can't imagine where I went wrong.. I had great faith that choking my co-workers all day was going to be worth it.
