REAR WINDOW SURROUND PATCH!!!!!
everyone fixing up and old 66-67 if not all the years has this area that needs repair work done. i would love to get the whole part or at leat the lower portion reproduced
Do you mean this piece? Lower rear window channel forward of trunk lid?
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Ace Wilson's Royal Pontiac http://www.youtube.com/watch?v=cUHC-Z8xhtg |
i meant more up the sides, my rear panel like that is in decent condition, but the corners of the window chanel up of the pillar area arent in good shape
I used Dynacorn part #'s
Filler panel = D11#1545 Small piece of each, Chevelle parts Driver wing = D11#1475AX Pass Wing = D11#1475BX Worked out OK. Charles |
The Following User Says Thank You to Old Goat 67 For This Useful Post: | ||
Oh, and put drains in those corners.
I used copper tubing and brazed them in place. Rubber hose down throught the flat area over the axle. Some people go into the wheelwell. |
Very impressive Charles!,..Did you flare the end of tubing and drop into hole?,..The stitch welding tacks I'm sure were staggered until solid,..did the patch butt into a flanged joint or butt straight into the adjoining parent metal?,...Very Nice Work!!
Yes I did flare the tubing.
Butt welded the little patches all around. Came out very satisfactory. Thanks for the compliments. Charles |
That's cool, I didn't think they we're making anything like that.
