Old 03-04-2021, 01:00 PM
alsalp alsalp is offline
Do you run Dexcool or Glycol coolant?
  #42
Old 03-04-2021, 01:05 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
What did you do for throttle pedal?
  #43
Old 03-04-2021, 06:56 PM
S Courter's Avatar
S Courter S Courter is offline
I have used glycol coolant and have not had any problems. For a throttle pedal I adapted a later Chevelle style pedal that bolts to inside of firewall. Just had to weld a flat plate in the proper position to mount it to. Used a Lokar universal throttle cable to run from pedal to throttle.
Steve
71 Pontiac GT-37 400 4 spd (sold)
71 Formula 400 turbo 400 (sold)
01 Firebird T/A WS6 auto (fun)
64 Tempest Post car LS1/4L60E (Love It!)
65 Lemans Post car LS1/4L60E (More Fun)(sold)
73 Lemans GT 400/auto 1 owner 52k miles
69 El Camino LS1/4L65E (Awesome)
70 Pontiac GTO Convertible 400/400 Original
69 Olds Cutlass S W31 Numbers matching 4Spd 3:91 one of 569
  #44
Old 03-20-2021, 09:49 PM
S Courter's Avatar
Dakota Digital doesn't make a gauge system to fit the 65 Buick dash so I bought a universal set that would fit. Made a panel to mount them in and moved the light and wiper switches to a new position beside the gauges. The shift position indicator was in the dash panel also so I bought a column mounted indicator from a PONTIAC. Looks factory. Had to have a drive shaft made as the stock Buick drive shaft has a rubber insert at the rear that prohibited shortening it. Installed the drive shaft yesterday and took the Buick for it's first ride. Runs and drives excellent. The LS1 provides more than enough power to be fun!! No codes and no leaks. Needs posi and more tire but is a real "sleeper"as is!!
ID:	563031   Click image for larger version
Steve
  #45
Old 03-22-2021, 07:28 AM
Jim Doran's Avatar
Jim Doran Jim Doran is offline
Looks Awesome. Fantastic skills and design.
-Jim Doran-
1965 389 Tripower; 4 speed; convertible
2019 Tesla Model 3 Performance
2016 Chevy SS; Sold
2001 Toyota Tacoma 4x4
2008 Infiniti G35x
  #46
Old 04-01-2021, 09:55 AM
JSchmitz's Avatar
I see you moved the battery to the passenger side on your '65 Tempest. Did ya just get a Chevelle battery tray?
  #47
Old 04-01-2021, 05:58 PM
S Courter's Avatar
Hard to remember what I did on that one but that is a reasonable assumption. I may have modified the original though. I did this, primarily, so I could use the stock Trans/Am Battery cables that came with the motor.
Steve
  #48
Old 04-01-2021, 06:52 PM
JSchmitz's Avatar
I understand. It's either run a long starter cable or run a long feed wire to the distribution block. Better weight and balance with the battery on the passenger side I suppose.
