Old 11-16-2019, 07:33 PM
Half-Inch Stud's Avatar
First Stage i aint revealing...okay you beat it outta me; a 5" vacuum cleaner impeller.
2nd Stage I used an aluminum wheel about 3" made in Northeast U.S.A.
Old 11-16-2019, 08:25 PM
Stan Weiss's Avatar
Mark,
What RPM?
Stan
Pontiac Pump Gas List
Old 11-16-2019, 09:01 PM
Stan,
58,000 for 5", and 72,000 for 3". Elec power was 33VDC @ 70Amps. I went up to 45 V for rpm headroom on the motors but still keeping the rpms about same. Fairly INSTANT boost.
these rpms vary depending on 2-stage vs single stage eval because the outlet is 14.7 PSI. I use a Cal'd Orifice 2.000" hole is a 4" pipe. Really need a venturi or other low restriction path to show better numbers. Good enough numbers are showing soi have conservatism.
Old 11-28-2019, 12:30 PM
GTOGEORGE's Avatar
So part two of the electric supercharger video came out on YouTube, this time it was the drag strip part. So they picked up 1 1/2 sec and almost 10 mph (from 16.9 et to 15.4 et) at the drag strip (1/4 mile) using the supercharger on the 4 cylinder......pretty darn impressive. They’re going to follow it up with bolting 2 of the electric superchargers to it (Dyno then drag strip results).
GTO George
Old 11-29-2019, 11:59 AM
GTOGEORGE's Avatar
What’s nice about these electric superchargers are there is no lag in power......instant boost/power!
GTO George
Old 11-29-2019, 12:14 PM
Stan Weiss's Avatar
Originally Posted by Stan Weiss View Post
Unlike Turbo or supercharges where boost ramps up with RPM. It looks to me like when the TotqAmp is turned on you have full boost. So like a nitrous shoot this should greatly increase mid range torque to a much greater amount than the peak HP increase would indicate.
Stan
GTO George
I guess you forgot what I posted 2 weeks ago.
Stan
Old 11-29-2019, 12:22 PM
GTOGEORGE's Avatar
Stan
Nope just kinda reposted.
GTO George
Old 11-29-2019, 01:30 PM
70 bird's Avatar
70 bird 70 bird is offline
Put about 10 of these things on a 455 and power it all up with a forklift battery!
Old 11-29-2019, 02:30 PM
GTOGEORGE's Avatar
I’m thinking 4 would probably do the trick at 48 volts!
GTO George
Old 12-05-2019, 05:48 PM
GTOGEORGE's Avatar
GTO George
So Part 3, a follow up on the Electric Supercharger........they dynoed the 4 cylinder with 2 Torqamps on it ant it picked up 50 HP from one Torqamp thats 105 hp stock, 150 hp with one and 193 with 2 electric superchargers! Pretty Damn impressive...........now if they could make a larger one..........Hmmmmmmm!
GTO George
Old 12-05-2019, 06:36 PM
Shiny Shiny is offline
This sounds like creatively cost-effective genius!
I'm a little surprised a vacuum cleaner part survives 58K rpm. Not doubting you, I'm just ignorant of vac cleaner blower rpm and construction. That sounds like a lot of centripetal force on a part made for a home appliance!
I guess good news is I'm not flying in the plane powered by a vacuum cleaner blower!
Again, I'm just ignorant and curious, but what kind of motor turns 58K rpm?
Old 12-05-2019, 06:37 PM
Tom Vaught's Avatar
Boost Engineer
Simple Math, $2500 times 2 = $5,000 for the two electric turbos.
For $5,000 it has been posted the HP gain was 100 additional hp on the 4 cylinder engine.
I believe Charlie has less that that amount in his entire Turbo system and made 700+ hp from 200 cid.
So in my opinion it is a massive waste of money vs the cost. Just like the Torqstorm superchargers needing two of them to make any halfway decent power.
Turbochargers and a bit of fabrication skill gets you 4 times the power.
Tom V.
Old 12-06-2019, 01:17 AM
GTOGEORGE's Avatar
GTO George
So this proves that and electric supercharger WILL work and make HP. Hook up a couple of wires and a few hose clamps was all that they did (maybe 30 min tops)........no tuning, no performance camshaft or head work just a bone STOCK SMALLISH 4 cylinder around 120 cubes............pretty damn impressive! One supercharger kit cost $2,500 but you would only need a 2nd supercharger without the extras in the kit.....probably cost ya ONLY around $3,500 all together!! Ill bet 2 would work on a 350 pontiac engine. Now what they need to do or someone is make a BIGGER one, can we say 455 ci.......ya man!
GTO George
GTO George
Old 12-06-2019, 01:18 PM
Tom Vaught's Avatar
Boost Engineer
You can do a bunch of bottle refills on a Cheap NOS 125 HP shot for $5,000.
Just saying. And where are you going to get 48 volt power. Battery costs and battery boxes are not cheap.
Beating a dead horse for a 100 hp improvement.
But do whatever you want. Waste of time when you could be making some decent power with a turbo for the same money.
Tom V.
Old 12-06-2019, 01:38 PM
GTOGEORGE's Avatar
Again people need to do the research on some products so their information can be correct........just saying!
GTO George
Old 12-06-2019, 03:43 PM
Tom Vaught's Avatar
Boost Engineer
Done with this one as same old info that was known 6 years ago when I was doing Research and Testing of Electric Supercharger at Ford Research as a job.
I am sure that the guys who made the video had fun but fun vs getting paid to do the job is a whole different story. Kind of like Racing for Fun and Getting Paid to Race for a living.
Tom V.
Old 12-06-2019, 04:03 PM
GTOGEORGE's Avatar
Originally Posted by brooknice View Post
I was on you tube and saw this video about electric turbo charger and this product look legit. It would be easier that all of the headache of tubing with a turbo. What do you guys think about this kit??
https://www.youtube.com/watch?v=7a_J2X88fSE
https://www.kickstarter.com/projects...c-supercharger
I think it would work on a 350 or under cubed engine IMO! They are easy to install and for an extra kick in the pants it seems it will work but for larger cubed engines a BIGGER one need to be made. JMO from decades of racing/and working on and with a Supercharger!
GTO George
  #38
Old 12-06-2019, 04:56 PM
Stan Weiss's Avatar
Tom V.
Tom,
Not everything is developed to the OEM standards / quality you had at FORD. But that does not mean that it may not be a useful produce for some people to use.
Stan
  #39
Old 12-06-2019, 07:32 PM
Tom Vaught's Avatar
Boost Engineer
Tom,
Stan
Since you responded to me Stan, I will try to reply to your last post.
1) Known Fact #1 12 Volt Electric Superchargers do not move air nearly as well as 48 volt Superchargers (due to the power available to drive the supercharger compressor wheel).
2) Known fact #2 12 volt Superchargers and 48 Volt Superchargers are not designed exactly the same way. THEY ARE DIFFERENT.
We tested both designs on the same cell under the same conditions.
The 12 volt systems are not designed to run at 48 volts, any more than your USA TV is designed to run a different voltage in a different country. Changes are required. You being a world traveler would know this, I assume.
3) 48 Volt systems designed properly along with 48 volt automobile charging systems and batteries have a great future IF the public were willing to accept them and the aftermarket suppliers had the ability to supply those 48 volt batteries and related components in volume. They do not currently have that capability.
4) You can't just hook up a set of four 12 volt batteries and expect them to function like a true 48 volt system in a car. VERY GOOD WAY TO GET PEOPLE HURT MESSING WITH STUFF THEY KNOW LITTLE ABOUT.
Maybe down the road the OEMs will have the proper 48 volt charging systems and related parts available to the public and then the 48 volt supercharger guys like Borg Warner and others will offer 48 aftermarket parts and knowledge to make they work properly.
Otherwise you are treading down a dangerous path for the person who wants to EXPERIMENT with higher voltage electricity on his vehicle.
I post to save peoples lives on E-Boost, not to give them bad info and advice.
Tom V.
  #40
Old 12-06-2019, 08:12 PM
Stan Weiss's Avatar
I don't know if anyone has ever seen the video of the model airplane that was build and used a leaf blower for it power / propulsion.
Using the same idea. I see a RYOBI leaf blowers going for $129 specs 160 MPH / 520 CFM. So if I take 3 of them for less then $400, I have 1540 CFM. On a fair size engine I can get a 2:1 pressure ratio. I can have a fun day at the track with them and a few spare battery packs.
Stan
