Old 10-21-2023, 07:09 PM
dv657172 dv657172 is offline
Default Glove Box Light - 71 GTO
So put in a new repop Glove Box light in 1971 GTO. Light works fine but door doesnt close tight enough to turn light off. Any solutions or similar problem experienced by others?
Have same switch in a 65 glove box which works fine.
Old 10-21-2023, 07:48 PM
indymanjoe's Avatar
i put a small rubber nipple on the stem of the plunger. put my phone in the glove box on video to make sure it went off barely shut and fully shut. lot of battery drain issues if this stays on.
Old 10-21-2023, 08:10 PM
Thanks Joe, great idea!
do you recall the item or source you got the nipple from?
Old 10-21-2023, 08:20 PM
indymanjoe's Avatar
some generic piece of whatever i found in my garage LOL maybe lowes or a hardware store near you would have something in the bin of miracles as i call it.
Old 10-21-2023, 08:23 PM
Time to get creative, thanks again
Old 10-22-2023, 11:14 AM
DavesGTO's Avatar
DavesGTO DavesGTO is offline
The piece of metal the switch mounts to can be bent. I bent it out just a little bit and it shut the light off.
Old 10-22-2023, 02:26 PM
Thanks Dave, will give that a try for sure!
Old 10-22-2023, 03:17 PM
I thought mine was doing the same thing. Closer look showed the plunger stem was pushing sideways due to slop in receptacle. I put double sided tape on a small washer over top of plunger to receptacle to help guide it straight as it pushed in and all is good.
Old 10-23-2023, 07:41 PM
Update - Issue solved
Bent the tab on the side of the glovebox out a bit and moved the latch hook at the top of the glove box back a hair to pull door in more
Problem appears to be solved. Plunger did not seem to have any excess play but will keep the washer in mind for future reference.
Thanks to all those who replied!
