Old 03-10-2024, 07:02 PM
64Lemans 64Lemans is offline
Default 1969 Pontiac Firebird Front Directional Rubber Boot / Connector
hello. my buddy has a 69 Bird. looking for a pair of rubber boots (the connector that plugs into the directional housing if you will. not exactly sure what its called. i've attached a quick pic displaying what i'm looking for. hopefully the pic helps a bit. not sure what the part is actually called. instead of buying a full wiring harness i'm looking to buy just the rubber boots and slice into the existing wires. the ones i currently have do not make the best contact thus juggling it a bit, the directional will intermittently work and then it won't.
any input / help would be greatly appreciated. thank you.
Name:	rubber boot for front directional 1969 Pontiac Firebird.jpg
Old 03-11-2024, 07:11 PM
Default front parking light rubber connector
to clarify...its the front parking lights. please see attached pic.
Name:	parking light.jpg
Old 03-14-2024, 12:39 PM
mrennie's Avatar
mrennie mrennie is offline
Have not seen just the plug available alone. You would need to get some cut off a GM harness or buy a complete "Forward lamp harness" that would have them.
Note that the GTO plug of 69-70 should be the same.
Michael
Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done...
Old 03-14-2024, 09:33 PM
4dblnkldude's Avatar
I have a bunch of old wiring harnesses, Ill look tomorrow.
Old 04-19-2024, 02:59 PM
The repro parking lamp units have hopeless bulb receptacles.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
