Fan Clutch measurement
Can someone at PY measure your fan clutches for me? Need to measure from water pump mounting flange (engine side) to the fan mounting surface on GME04 and GME05 fan clutches. Measurement should be in the range of 1 1/2" to 1 3/4" or something like that.
I have a non A/C 389 with GM 8 bolt water pump, 4 row radiator and shroud and original fan. With current fan clutch the fan blades are just barely into the shroud about a 1/16 of an inch. I would purchase either GME04 or GME05 from PY if it moves the fan farther into the shroud. I don't want to order and find out it is too short and have to pay shipping both ways. Hope you can help me out on this. Thanks in advance. Jim
"Never try to teach a pig to sing. It's a waste of time and it annoys the pig" |
We'll get an answer to you tomorrow.
--------------------------- Fool Around, Get Hurt, Don't come Crying to me. |
Jim --
Both the GME04 and GME05 Measure 1 1/2". |
Thanks for checking, I really appreciate it! Unfortunately that is what I currently have.
Jim
No Problem!
Jim, what's the diameter of you 66 non a/c fan?
I need to get the shroud and fan clutch for my 66. I've got a 19" 6 blade fan that I believe is for a later year, and won't work with a 66 non a/c shroud.
