Old 05-09-2024, 08:42 PM
BLACK70GTO's Avatar
BLACK70GTO BLACK70GTO is offline
Default Camshaft Identification
Can anyone help me identify this cam ?
Solid roller
Thanks David
Old 05-09-2024, 09:17 PM
It's a Comp Cam. 304/319 durations, 104 LSA but I don't know what the + is for?
Mine is almost exactly like that except it has 104 not a + in it.
Old 05-09-2024, 10:06 PM
Steve C. Steve C. is offline
110 LSA with 4 degrees advance ground in.
Old information here:
The Following User Says Thank You to Steve C. For This Useful Post:
Old 05-09-2024, 11:27 PM
There is the name Kevin Mendenhall on that picture.
Could this be the same gentleman here:
https://www.bnmperformanceandmachining.com/
If so he might have more information to share.
Old 05-10-2024, 06:21 AM
BLACK70GTO's Avatar
Default Cam
Yes
Kevin is my engine builder
This cam came in a Engine I purchased just trying to see if it will work in my application.
Thanks David
Old 05-10-2024, 08:31 AM
Tim Corcoran's Avatar
I would call Comp Cams and they should be able to get you a cam card with all the specs.
Tim Corcoran
Old 05-10-2024, 08:38 AM
BLACK70GTO's Avatar
Default Cam
Thanks they did get back to me.
Thanks to all that helped !!
Old 05-10-2024, 11:06 AM
For interest would you mind sharing the information Comp came up with.
In particular I'd be interested in the lobe lift for both intake and exhaust.
I tried doing a cursory look at the 304 & 319 degrees rated duration to what it might correlate to in the amount of duration at .050" tappet lift.
But you can't refine a search unless you know the lobe lift on the cam.
Old 05-10-2024, 11:09 AM
BLACK70GTO's Avatar
Default Cam info
Cam info
Old 05-10-2024, 11:54 AM
Thank you.
For interest the intake lobe correlates to HI-TORQUE .406" ROLLER lobe number 4208 on page 88.
The exhaust lobe is similar to a HI-TECH ROLLER lobe, some are listed on page 75.
Keeping in mind Comp has thousands of lobe designs not listed in this catalog.
https://edelbrock-files-v1.s3-us-wes...be-Catalog.pdf
Old 05-10-2024, 03:28 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I have the 268/272 Hi Torq lobes in my 500" motor. So you are a step bigger
Skip Fix
Old 05-10-2024, 04:21 PM
FMile Pontiacs's Avatar
FMile Pontiacs FMile Pontiacs is offline
I hope you can use it for your combination If you don't, I might be interested in it. Joe
