Old 03-26-2024, 10:44 AM
Jim Perez Jim Perez is offline
Default Difficulty opening hood
Good morning, all,
Having trouble opening my hood on my 69.
First off, doesn’t pop up well. Have to work at getting my fingers in between. Weak springs? Or weak popup rod?
Main problem, latch doesn’t open all the way, I really have to work at it with pulling the handle. Weak latch spring?
Maybe I need a new latch assy?
Thank you,
Jim
ID:	631072   Click image for larger version
Old 03-26-2024, 06:16 PM
VCho455's Avatar
VCho455 VCho455 is offline
Inspect the latch receiver (circled in photo) in the hood. Make sure that the spot welds are still holding and the receiver can't move side to side in the hood stiffener.
Old 03-26-2024, 06:56 PM
tom s tom s is offline
Jim,springs might be getting weak.I found some helper springs that fit inside the factory springs.They are Volvo springs,real EZ to put in if you find them.Tom
Old 03-28-2024, 08:01 AM
gto4evr gto4evr is offline
I'd put the resistance more in the rivets/bushings on the hinge frames than the springs getting weak. had a friend send out a set of hinges for new bushings and rivets and it was amazing how smooth and easy that hood came up afterwards.
that's expensive though. for mine it's some WD40 and work the hood up and down to loosen the hinges up a bit!
Old 04-19-2024, 03:20 PM
Hood alignment to the latch assembly is a common cause of the hood not popping.
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
Old 04-20-2024, 06:17 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
agreed.
seeing the pics from the original post it appears there's abrasion/ rubbing on the one side of the latch assy- perhaps it's binding here with the engine hood when closed? It may be worth looking into trying to adjust this latch position.
Long live the Muscle Car
Instagram @tuske427
1967 Firebird #BVbird
1967 Firebird 400 4 speed project
1969 Verdoro green GTO (daily)
Old 04-24-2024, 02:07 PM
Thank you all!
