428 Build Comments
We're using a standard bore, standard journal size, 4 bolt 428 block for a '68 Firebird with overdrive automatic, 4.11 gears, FI, Edlebrock 87 cc D-port heads. Will use stock crank, Eagle rods, Diamond pistons for 9.6:1 compression.
When talking to the builder about cams, he suggested Comp Cams Extreme Energy Series with their SOLID LIFTERS. They offer a lifter with a .012" hole in the bottom cam surface, for improved lube to the cam. He does not like any of the retro hydraulic roller setups. I was concerned about valvetrain noise with a solid cam, but he says these run with minimum lash so you'd never know it was not a hydraulic cam. What have you heard?
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
