lights on with wipers
As you probably know most states now require your headlights be on whenever your wipers are on. Does anyone know how to get the lights on a 1964 GP to come on with the wipers? The wiper motor always has voltage when the key is on and the switch GROUNDS the motor. I thought I had it figured out by using a relay and grounding the relay with the wiper switch. With the plug disconnected from the wiper motor everything worked great but when the plug is inserted back in the motor the relay stays engaged and the lights stay on all the time. Evidently the relay must ground through the motor windings. Any thoughts?
