Old 05-13-2020, 04:07 PM
Brewster's Avatar
Brewster Brewster is offline
Default Vacuum Canister
Does anyone have an original canister they can post a picture of and is there a difference between 68 and 69 ?
Old 05-14-2020, 07:26 PM
kk68's Avatar
kk68 kk68 is offline
Here’s a fenderless photo where you can see my original canister mounted on the inner fender well. This is an Arlington built car. This one has 8 ribs. There may be other versions with more or less ribs based on factory and supplier. I think there was an old thread about this.
Don't rush me - it's only year 20 of the 3 year restoration!
68 GTO convertible
YS M40, A/C, PS, PB-disc, Posi-T, PW, P-seat, AM-FM stereo 8-track,
P-ant, P-trunk lid, Tilt-S, Rally gauges, Hideaways
C1 224 Triple white
Old 05-14-2020, 09:49 PM
Va68goat's Avatar
Va68goat Va68goat is offline
Default Vacuum can
Here is the vacuum can off my 68 GTO. I'm not actually using it because I'm using a Leeds vacuum pump to run the hideaway headlights.
https://leedbrakes.com/i-23439163-el...it-series.html
ID:	540233   Click image for larger version
ID:	540234   Click image for larger version
ID:	540235   Click image for larger version
Old 05-14-2020, 10:35 PM
Brewster's Avatar
Thanks guys! My car is an Arlington build too with a late June date. Will find the 8 rib to use for my build. Appreciate the help and info.
Thanks, Brew
Old 05-19-2020, 07:30 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
54,xxx original. Pontiac car. 03c build date 8-rib vacuum canister.
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
Old 05-20-2020, 09:56 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
My January 68 Pontiac MI built has the 8 rib with the space in the middle just like the other two above.
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 05-22-2020, 07:14 AM
68ragtop's Avatar
Or should I say had........ I still have it, but its a leaker that I could not repair without it looking like heck, so I bought a incorrect looking repop in the hopes I find an original, or a correctly made repop someday.
89 Trans am GTA
Old 05-22-2020, 09:21 AM
dataway's Avatar
dataway dataway is offline
Of all the reproductions out there that ARE correct, you wouldn't think a freakin tin can with the right ribs in it would be a problem to make. They should talk to a coffee company or something, maybe they could help.
Old 05-23-2020, 06:42 AM
68ragtop's Avatar
Truth be told, I felt the same way & was trying to fix mine, but rust from the inside out kept causing pinholes.
Sooooo, while searching for a replacement I noticed that OPG was the only seller that had the correct looking ribs, but nearly twice the price.
Then they had their "Christmas special" which brought the price a little closer to competitive & I decided to purchase it.
When I got it, I found out it was the exact same as the one every else was selling, just more money.
Called & they would allow me to return it, but after shipping costs I would have the same price as it would be anywhere so I just kept it.
Gave them my opinion & not too long after they changed their pictures to match what they are selling.
Buyer beware
89 Trans am GTA
Old 05-23-2020, 07:22 AM
Brewster's Avatar
Yes, its like the one on ebay by joparts or well you know their name. They wont reply when asked if it leaks or has pin holes...?? so imagine it does. Nothing worse then a seller that wont rep the product that they are selling. Buyer be aware on that one too.
Old 05-25-2020, 12:16 PM
Brewster's Avatar
Was the four ribber before the eight or just different mfg? I found a 4 ribber but hate to use the wrong part(s). Thanks
Old 05-25-2020, 08:53 PM
brians's Avatar
brians brians is offline
You would not believe how many thousands they want you to purchase to create a custom can.
“If you ain't first, you're last” - REESE BOBBY
Old 05-25-2020, 09:55 PM
dataway's Avatar
You'd think with modern CNC rolling equipment and desktop to factory prototyping it would only be a couple hundred bucks setup fee.
Old 06-02-2020, 09:10 AM
rasilverbird rasilverbird is offline
For the guys that have pinholes, this stuff works great
https://www.por15.com/POR-15-Fuel-Tank-Sealer
It requires prep work with other POR 15 products, so read the instructions first. If you don't have any large holes, I would give this a shot.
1968 GTO - 400/400 - Currently being rebuilt - 455/T56
1996 WS6 - LTI M6 - Sold 5/11
1979 Trans Am - 403/Auto - Sold 12/18
Old 06-03-2020, 02:09 AM
Doesn't it seal from the inside? How would you get it into the vacuum can? It only has a little 1/8" or so diameter tube and that's the only opening.
Old 06-03-2020, 05:49 AM
68ragtop's Avatar
My orignal looked decent until I bead blasted the paint. Ventilated it around some of the seams. I used JB weld from the outside & figured it would not be visible from the way its mounted, but I kept chasing little pinholes & I gave up. Not sure how you would get POR15 inside. The stuff is pretty thin, but that is a small vacuum port. Possibly a small funnel on a vacuum tube, then stick a wd40 straw through to let the air escape the container as it goes in? Might not be enough room to do that, but maybe?
89 Trans am GTA
Old 06-05-2020, 09:48 AM
Held for Ransom's Avatar
Can't imagine trying to gas tank seal/Por-15 the inside.
Brew, yours is a '69, right? Anyone let you know on that year?
ID:	541798   Click image for larger version
ID:	541799   Click image for larger version
So long, farewell.
Old 06-05-2020, 11:08 AM
Brewster's Avatar
Yes, and an Arlington car at that. According to my findings the 4 rib can was for 68 and the 8 rib can for 69. I found a killer 4 ribber but still need a usable 8. Is that one available Ransom? Let me know since Im in your area monthly.
Thanks, Brew
Happy Friday!
Old 06-05-2020, 01:28 PM
kk68's Avatar
Thanks, Brew
Happy Friday!
My 68 is Arlington built 04C and has the 8 rib vacuum can. I would guess that the 8 rib versus 4 has more to do with assembly plant and vendor source than 68 vs 69, but I have no definitive knowledge.
68 GTO convertible
C1 224 Triple white
Old 06-05-2020, 02:13 PM
I looked at my 69’s, past and present (Photos on past cars)... all cars were-are survivors, all California built and all 5 are 4 rib. Two are oct 68 build, one is feb 69, one is April, and July. I do have an 8 rib from a spare 69 hideaway setup, not sure where it was built but probably Baltimore (almost all the local cars here were).
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
