Old 07-26-2023, 11:32 AM
Old Goat Racer's Avatar
Default What is it ?
A couple weeks ago we destroyed a high 11 sec. 455 motor.
So we put together an old well used 400 motor .
Same intake manifold.
Started it up, sounded good, ran for 5 minutes and died.
Restarted motor and heard a loud knock.
Pulled motor, pulled pass head and found this piece of metal on top of piston.
What is it and how did it get there ??
ID:	616745   Click image for larger version
ID:	616747   Click image for larger version
ID:	616748   Click image for larger version
Everybody knows somthin.
Nobody knows everything !
Old 07-26-2023, 11:41 AM
leeklm's Avatar
leeklm leeklm is offline
Piece of metal from the 455 get trapped in the intake manifold and fall out when installed on the 400?
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
The Following User Says Thank You to leeklm For This Useful Post:
Old 07-26-2023, 11:53 AM
400 Lemans's Avatar
400 Lemans 400 Lemans is offline
Kinda looks like a piece from a broken pushrod.
Old 07-26-2023, 12:07 PM
einstein's Avatar
einstein einstein is offline
A chip off the old block!
The Following User Says Thank You to einstein For This Useful Post:
Old 07-26-2023, 12:14 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Looks like a smashed piece of key stock.
Old 07-30-2023, 09:04 PM
boybonneville's Avatar
boybonneville boybonneville is offline
Send a message via AIM to boybonneville
Kinda looks like a metal plug, kinda small freeze plug looking.
Old 07-31-2023, 12:25 AM
Looks like the end of the dipstick tube smashed flat.
Hiding inside the intake manifold and ending up in the next engine.
Old 07-31-2023, 06:14 AM
steve25 steve25 is offline
It's got that light goldfish copper color that tells me it was part of the dip stick set up or factory windage tray if you where running that.
Old 07-31-2023, 08:11 AM
WOW!
You and Tim could have matching mementos.
(thread in Race section)
Old 07-31-2023, 12:19 PM
NO broken pushrods. All pistons were still in their holes. We put together a mild 400 with a different set of heads same intake. The piece almost looks too big to pass through the intake valve. Scratching our heads. Put 400 back together, running fine, just slower.
Old 08-01-2023, 11:15 AM
400 Lemans's Avatar
What about a missing vent tube on your Holley?
Old 08-09-2023, 11:32 AM
BINGO ! I finally got to see the carburetor and sure enough the back VENT TUBE is missing. What made you think of that ?
Thanks, OGR
Old 08-09-2023, 12:26 PM
400 Lemans's Avatar
The color of it and how it would have gotten in to your intake runner in the first place.
The Following User Says Thank You to 400 Lemans For This Useful Post:
Old 08-09-2023, 01:05 PM
dataway's Avatar
dataway dataway is offline
Crowd sourcing information ... wonderful thing to see.
Nice work 400 Lemans!
Old 08-09-2023, 01:17 PM
JSchmitz's Avatar
Give that man a cigar!!! Nice work!
