BOV question, where to run the reference line?
I just put a BOV on my 78 T/A, should I run the reference line under the carb with the pressure gauge or should I run it from the hat with the fuel regulator line?
Johnny US Army Retired 1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
Intake manifold close to the carb base.
*** THE BIG BRACE is here *** |
Make the signal line as short as possible and and get a large BOV as a large BOV will never hurt you but too small of a BOV will cause issues, (especially with belt driven centrifugal high hp superchargers).
Tom Vaught
Here is what I got,
So what size is the valve, Johnny?
Tom Vaught
Hi Tom, I think the valve is 1.5 inches
That should be ok for a street/ strip deal. If you race very much you would want a 50mm
plus valve (~ 2.0") Tom Vaught
FWIW:
From personal experience I have found that once you start forcing air in the engine around 10/12 lbs of boost or so would be a point I would start looking at a BOV over 1.5".
Johnny, Cost effective. I used 2 - 1.5" valves at 1/4 of the cost and 16lbs of boost. Lots of them going on E-bay cheap. They worked. |
The big units from JGS/TIAL/TURBOSMART is the way to go... I'm thinking about upgrading to the 60mm JGS bov. It's priced at 230$ new from JGS (made in USA).... that's hard to beat.
This is the cheapie I bought, more as precautionary. My BDT is "supposto" be making 7-5PSI. My S-W gauge has shown 12-14 so I will try a different gauge before I do much more.
http://cgi.ebay.com/ebaymotors/ws/eB...m=380176932887
P.S. Turbo's run off exhaust pressure/flow not with a belt. Just stating the facts... LOL
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride! |
It's about 6-7 at idle and quickly jumps up to 12 by 1100 and levels to 14 at 3500 according to this gauge that is a bit beat up so I want to verify it with another. I think I will order a Summit 2802 for it when I get paid. At 8.3:1 compression with the XE274 and "potential" 12+ psi might be a stretch. It uses Gates 5M pitch belts usually seen on scooters or industrial equipment. I need to re-count the drive gear, it is either 82 or 88 teeth and the driven gear is 23 teeth.
Well that confirms the need for extreme caution! I just checked the boost chart over on P-Dudes website, if you have a static compression of 8.5-1 when the boost hits 12-14 lbs the dynamic compression is between 15.4-1 to 16.6-1!!! It's higher than I was expecting for sure. JD
Here's the boost chart: http://www.angelfire.com/fl4/pontiac...owerboost.html
Wastegate would regulate the boost.
Not on a centrifugal supercharger and that's what he's running.
I don't want to be a kill joy here, so take this for what it's worth, especially me never having seen this unit before:
I sincerely doubt that you're building that kind of boost with that set-up. I think you'll shred the belt immediately. It looks like the driven pulley is directly attached to the compressor wheel shaft, which is probably why the small belt is able to spin it. If there was a "gearbox" attached to it, higher impeller speeds and more boost would be achieved. I think the current impeller speed will max about 20k rpm or so (rough math here). Making 7lbs of boost at idle does not sound right at all. Typically you need the throttle blades open to make boost. (meaning spinning the engine some) I'd swap the gauge and check again. Might want to get a vac/boost combo. I also think the bracket set-up would not be happy at all if you were making 12lbs of boost. hope my rambling hasn't pi$$ed anyone off. |
