Old 03-24-2024, 11:39 AM
performerrpm's Avatar
Default dowel bearings for pontiac rj
are these available anywhere? hows the best way to go about making holes if theyre not? i saved some old rod caps and thought about trying to drill and make a jig but if theres a better way
Old 03-24-2024, 09:46 PM
Formulas Formulas is offline
I have a stock rod cap that a machinest drilled and installed a drill bushing in it for me for my BME rods i can loan it to you, might want to verify same size hole first i can check tomorrow
Jim Zeek's Avatar
Jim Zeek Jim Zeek is offline
what size bearings? you can buy a jig
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial
http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1
Old 03-24-2024, 10:35 PM
i may take you up on that, i dug up a few caps to ask my machinist if he could make me the sa.e thing. i free handed one and actually got a good fit but ii probably couldnt duplicate it to save my life.
im working with a set BME rods too
Old 03-24-2024, 10:36 PM
pontiac rj size
Old 03-24-2024, 11:49 PM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
A drilled old cap works fine for me. Not enough use to warrant a drill bushing.
I've also bought pre-drilled bearings at times.
Old 03-25-2024, 05:44 AM
does the hole need to be exact in size or can it be just a little bit loose fitting?
Old 03-25-2024, 06:24 AM
It can be a couple thousands too loose since the dowel is there to keep the bearings from outright spinning during loads where the big end gets distorted .
It's not ment to replace Bearing crush, it's just the last line of defense against a spun Bearing.
If the dowel hole is not dead on then it's better to have some play so that the ends of the Bearing line up the way they should at each parting line.
Old 03-25-2024, 09:34 AM
the one i free handed was .003 off from being perfectly centered, but. the hole was exact and once i bolted the 2 halves together, the parting line match perfect but to me it looked like the bearing moved closer to the radius of the rod. i went a tad bigger on the hole and it gave enough to match it up both at the parting line and along the radius.....a jig should work wonders...i might just buy a drill press
Old 03-25-2024, 11:32 AM
Oh gez yes!
Trying to get it right without a drill press is not the way to do this.
Old 03-25-2024, 11:34 AM
Oh gez yes!
lol , no i wasnt gonna. i was meaning i might get a drill press and try making my own jigs as well as do my own bearings. vs having them made at the machine shop.
Old 03-25-2024, 04:43 PM
I did the same when I ran pinned bearing aluminum rods-an old cast iron rod cap. Made a paper template of where on the luminum rod it was located and transfereed that to the rod cap. Then drill press for sure!
