Old 08-13-2021, 06:42 PM
davidgto davidgto is offline
Default Engine ID
Friend just pulled engine for a rebuild.There is no ID on front of block such as WS or WT. No numbers either. The date code on dist pad reads II47. Just behind passenger side head on block, reads 9792968. Any help appreciated.
Old 08-13-2021, 07:07 PM
1_Wild_Cat's Avatar
A quick Google of the number says...it's a 428. The date would make it a '68 model year.
Old 08-13-2021, 07:20 PM
Default xxxxxxx
Has 3 freeze plugs, if that helps.
Old 08-13-2021, 07:24 PM
Default xxxxxxxxxxxxxx
I thought the 428 engines had 428 on the side of the block. THere is nothing on this block.
Old 08-13-2021, 07:33 PM
Tom Vaught's Avatar
Boost Engineer
455s do, not sure about 428 engines.
Tom V.
Old 08-13-2021, 08:03 PM
jeff chmura jeff chmura is offline
My 428 has 28 in the center of lifter valley and also 428 on LH side of block
1968 YH code
Old 08-13-2021, 08:06 PM
thepontiacman's Avatar
Some 428's have 428 in between freeze plugs.
Sent from my Moto Z3 Play using Tapatalk
Old 08-13-2021, 09:37 PM
Default xxxxxxxxxxx
We have not looked at the lifter valley yet, but nothing on the side of block.
Old 09-12-2021, 07:06 PM
John V. John V. is offline
The lack of a Manifest Code stamping and Engine Unit No. might be because it was ground off. Otherwise, it may have been a block used for a Service Replacement motor. If SR, look for a stamping alongside the Timing Chain Cover a few inches below where you would normally find the Manifest Code stamping.
SR blocks would not get a Manifest Code stamped on them.
I'm no expert on the '68 cast 428 blocks but I'm guessing since this was a pretty early model year block casting, very possible the additional identifiers cast on the side of the block had not yet begun at the time this block was cast.
