Old 09-25-2021, 03:38 PM
jhnichols2 jhnichols2 is offline
Default 64 Convertible Brake Swap
Changing my 64 convertible from factory front drum brakes to factory 69 single piston caliper power disc. I want to keep it looking close to stock. I plan on using a 68 distribution block mounted to the frame.
Would the correct front to rear brake line be 67? What brake booster do I need?
Will i need a separate proportioning valve? What abut the master cylinder?
Old 09-25-2021, 05:42 PM
What wheels do you plan to use?
Old 09-26-2021, 02:16 PM
I would like to go with stock 64 Deluxe hub caps, so I am thinking probably 14 x 6 steel wheels 68 -72.
Old 09-26-2021, 03:02 PM
GtoFM's Avatar
GtoFM GtoFM is offline
https://forums.maxperformanceinc.com...24#post5845024
Ck out this thread. It was mainly about routing front lines with RA exh manifolds but Cardo posts pics in #10 that may help.
Cardo sent me some great pics also.
Old 09-26-2021, 05:56 PM
Make sure the wheels will clear the 69-72 setup: some will not.
We do offer setup that will clear the 64 rims no issues
Old 09-28-2021, 08:10 AM
Andre's Avatar
Andre Andre is offline
The GM 14x7 or aftermarket 14x7 will clear both the 69-72 disc brake caliper as well as the 67-8 dual piston brake caliper. (which is what I have on my '64)
Old 10-01-2021, 05:53 PM
Thumbs up
Thanks.
