Old 11-20-2011, 10:08 AM
catalina_dream's Avatar
catalina_dream catalina_dream is offline
Default Comp Cams 288R - Any combos out there?
Is any one currently running (or previously) a combo using the Comp Cams' 288R solid roller (51-751-9)?
http://www.compcams.com/Company/CC/c...csid=1224&sb=2
Looking for info and opinions as I am thinking of pulling my motor over winter.
Current combo:
455 .030" over (stock stroke & rod length)
TRW flat tops
6x heads flow 244 @ .500" w/1.65 roller rockers
CR approx 9.3:1
Crower 60919 cam, degreed in
HSD ported to match heads (no plenum work)
Q-Jet w/stock style RA air cleaner (hood is open)
Car is 1972 Formula clone:
Full weight (3800+??), auto w/2800 stall, 3.73 gear
Hooker Super Comps w/full Flowmaster exhaust
Thinking about swapping to this cam and maybe an upgrade to the heads. I am not looking to rewrite any record books, just looking to step it up some and I can get a great deal on this cam and springs. Motor only has about 200 miles on it in 3 years so for now just the cam swap and maybe open the heads up. All opinions welcome.
Thanks - Kevin
1972 Firebird
462, 6X heads, RA4 cam, iron intake, Cliff's Q-Jet
3925 race weight
Best of 12.88 @ 105 so far
Old 11-21-2011, 11:55 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
We have that cam in a 455 with 71 HO heads, stock intake and q jet. I dont know if there has been any work done to the heads but it runs very well.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 11-22-2011, 02:23 PM
Default Thanks Jack
Thanks for posting Jack!
Anyone else with a combo?
152 views and no opinions? Hard to believe! Please share!
Thanks - Kevin
1972 Firebird
3925 race weight
Old 11-22-2011, 08:13 PM
Mike Davis's Avatar
I have put that cam in a few engines. Good street cam. Changed it out to a http://www.compcams.com/Company/CC/c...csid=1225&sb=2
and there was a noticeable difference. With the heads you are running I would like something with a split duration somewhere around 248/256@
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 11-22-2011, 09:50 PM
dmorg1's Avatar
dmorg1 dmorg1 is offline
Kevin,
Not exactly the combination your seeking information on but I'm running the 288HR in a 400 with 7K3 heads if you are interested.
Dave
68 GTO
68 LeMans
68 LeMans Convertible
79 Firebird
Old 11-23-2011, 10:10 AM
stickboy's Avatar
stickboy stickboy is offline
I'm running the newer XE lobe 242 248 solid roller w/ 1.65's. Like it a lot, could have used more cam, like the one mentioned above, but it is plenty streetable and pulls to 5800. If you do pull the heads, go to the 1.77 exhaust valve if they don't already have them. Get the flow up as much as you can. You can get over 200cfm from the exhausts pretty easily on the iron heads.....I would at least do that and then run it.
65 GTO, 3800#, 474, KRE Dport 330 cfm, 11:1 on pump gas, XE 242 248 solid roller, T56 trans, 3.90 gear, 11.26 @ 124 mph
Old 11-23-2011, 02:00 PM
Don 79 TA Don 79 TA is offline
i'm using the XE lobes 3317 and 3319
to me its sorta tame
but it does come on strong
i also have a 107 LSA and gets 9.5" vacuum at idle
i thought this cam would have been more radical at idle and its not
i have thought about the magnum line with the 304/314 with .4 lobe lifts
that should work nice with the round port heads i have
i did have a friend run the CC305 regular hyd cam, and man... did it pull great in his car
he swapped to a 288/292 XE roller and it was slightly more throttle responsive
Old 12-22-2011, 10:23 PM
Junkyard Dog's Avatar
I have that cam sitting in my closet, but I wonder if I should go to something bigger when I build my engine . . .
Badder than old King Kong
-Jim Croce
Old 02-03-2024, 06:05 PM
Steve C. Steve C. is offline
"We have that cam in a 455 with 71 HO heads, stock intake and q jet. I don't know if there has been any work done to the heads but it runs very well."
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Within the link I posted.
Old information here:
Old 02-03-2024, 07:25 PM
Sorry, above posted in the wrong thread. Sharing Jacks comments.
