Non Pontiac Motors in Pontiacs includes factory 403,305,350 Chevy, Buick V6, Also Pontiac Motors in non-Pontiacs! |
Your car is what I want to do to my 66 Tempest. I was thinking of an LS motor with a paddle shifted 6-speed automatic though, minus the HTH truck arm suspension too and just go with coilovers. Why did you have to set back the motor so much? Are you going to use headers?
the motor setback helps with weight balance and clearance from the tie rods to oil pan. it makes alot of other things a hassle though plus it made me keep cutting and cutting... i have a set of doug's headers #D338 to use. i think i need to plan some space for turbos though
i did get some more cage work done, check out the flics. |
Nice build. Subscribbing.
Have you locked in that engine/trans position? That trans does look awfully high in the rear - because the powertrain looks too horizontal to me. I would propose you need a 3 to 6 degree down angle on the engine/trans assembly and then match the rear axle to that (rather than the other way around). K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
No I have not locked in the driveline angles. When I get the car back on its wheels and set the ride height ill look at it again. The pinion angle at the rear was only around 1 or 2 degrees up if I recall. The trailing arms are so long it barely changes as it swings thru its arc.
this little digital angle finder cube is about the most useful tool I've been using for this work , I've got to give it a plug. $30 on amazon. And thanks for praising the welds! Last edited by Colin Frolick; 10-18-2013 at 03:59 PM. |
If the car is going to be significantly lower than stock, then I suggest that the current position of the engine and transmission is probably close. With the rear being lowered the rear of the transmission will need to be raised up significantly to keep the front u-joint operating angle in the acceptable range.
Andrew
IG: projectgattago Please get in touch for Holley EFI tuning services. "You were the gun, your voice was the trigger, your bravery was the barrel, your eyes were the bullets." |
Have most of the cage bars in. Still deciding on a v or x or just a diagonal in the roof. Kind of confining. Needs an x in the back. The sill bars are in, I'm making the upper door bar removable. The smaller bars are 1.5 x 0.095 wall erw. I was reading the rules again for the silver state and they have been revised so I could have used 1.75 x 095 instead of 120 wall for the main cage. That's like 1/2 pound a foot... Anyway I can still deadlift the front end so it's not -that- heavy. Made a few triangles in the front, seems to help with frame flex. I think I'm getting super lucky where the brake master cylinder clears the head. Reminds me of hemi dodge dart. Still figuring where things got to go. I think the engine needs to move forward about an inch. The body is held on by 6 tack welds for now haha. Check the ride height.
Upside
Inside
I didn't want to screw with moving the coils for aesthetics but look like I will be for space. Not the master I'm using but you get the idea
flics
that's tiny Thelma banging gears
cage is done, started on the trans tunnel should have it back on the wheels tomorrow also.... is this super tempest " I " ???? http://bangshift.com/blog/thundering...orts-cars.html |
more
next reattach the body, start building firewall and filling in sheetmetal
Cool build!
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
Thanks Boss
Some updates already, a few photos.
Firewall
Pedal mount, very rigid.
#38
All set up. Very comfortable and ergonomic. Handbrake from an e36 bmw is a clean fit.
#39
Headroom inside the cage is excellent, I'm pleased with that.
#40
I hated to ditch the original steering wheel but as you know it was pretty big around and mine was no longer round :-) so this one feels pretty nice. It's on a quick release hub.
