04-06 General Tech/Discussion 2004-2006 GTO General Tech and discussion. |
12-09-2013, 01:24 PM
Administrator
What did you do to your GTO today??
All the other boards have them. Why not start ours?
What'd you do to your Goat today?
"LIKE" Max Performance on Facebook!
"LIKE" Cold Case Radiators on Facebook!
"LIKE" GTOG8TA.COM on Facebook!
12-09-2013, 07:38 PM
Nothing today. But I have a pile of projects waiting to get worked on! First on the list is the H-Box and Pypes Exhaust!
12-09-2013, 10:20 PM
Nothing today and won't be for awhile. Both the Goats are hibernating at least untill May. Really thinking of installing a super charger. Our Goats are not the king of the hill anymore with all the new muscle being over 400 hp gonna have to do something to stay on top lol. I just can't stand my buddies super charged Camaro getting my Goat at the track!
69 GTO Judge
69 Firebird Trans Am clone
76 Trans Am 400 4spd.
06 GTO M6 18's red/red - 1 OF 188.
09.5 G8 GT Stryker blue met. premium with sport pkg.
12-10-2013, 11:11 AM
Administrator
That's what I like to hear
12-10-2013, 11:13 AM
Administrator
Our supercharged G8 test car is awesome...people always roll up to it thinking....stupid four door. Ohhh little do they know
The Following User Says Thank You to eric_cspan For This Useful Post:
12-10-2013, 01:40 PM
Installed my new gauge cluster only to find out that I need to have it programmed with a Tech II, *&&%$!!
1969 Judge (Liberty Blue / Blue, 4SPD)
12-11-2013, 10:49 AM
Disconnected the battery tender from my '05
Wheels on the '70 are out for sand blasting then will be restored.
Touched up paint in wheel wells frame rails.... for now.....
The order from PY to restore the wheels are in a box sitting waiting to be used.
President: GTO Association of America
www.gtoaa.org
12-11-2013, 02:23 PM
Administrator
Test-fitted PY's new "GTO" badge. This was just a sample. Production run coming soon!
12-13-2013, 03:11 PM
Administrator
Test fitted our new Fender Badges. The fit and look is superb. These are even better than GM's quality!
12-13-2013, 04:11 PM
Been missing it all week. I've got another week before I go home and get to drive it again I have all kinds of little projects to choose from though!
12-17-2013, 02:26 PM
Last night I threw on a new P&P stock TB, really increased throttle response dramatically.
2004 M6 YJ: AEM CAI, SLP LM2, SLP LT's, SLP UDP, P&P TB, BC Coilovers, Poly RR, strut, shock, subframe, and diff bushings, 05/06 brakes, DBS slotted rotors, Hawk Pads, B&M short shifter, MSD wires, NGK TR55 plugs, predator tuned staggered 245/275 tires. Oh and PY carbon fiber door handles and emblems ;-)
01-02-2014, 10:38 AM
Administrator
Getting it inspected this weekend!
04-09-2014, 11:13 AM
We should probably bump this up since I'm sure someone out there is working on their Goat!
I recently did new plugs, wires, and added some nice fiberglass sleeves to help with header heat. I have a new headunit on the way, a cluster trim gauge pod which needs to be fabricated, drilled/tapped GTO OFAC plate to add for my oil pressure sender, struts/shocks/springs/bushings/tie rod ends, and primary O2 sensors which all need to be installed! A little backlog...
04-09-2014, 01:28 PM
Administrator
Replaced the trunk struts on our test vehicle. Man, what a difference. The rear panel literally broke because of all the slamming!
We're reproducing these hood/trunk struts ourselves and will be dipping them in CF
04-10-2014, 04:37 PM
Reprogrammed the shift light to a real rpm , had it at 5000 so I could see it light up without screaming around the neighborhood too fast.
Replacement Aeroforce gauge coming in today one went out after unplugging to program shift light. They look good in the SCSS gauge pod.
Cussing about how bad the clear is lifting and the paint those Aussies used!
Skip Fix
04-14-2014, 12:59 PM
Administrator
Finally got to replacing that ugly orange rear arrowhead with one of ours
06-04-2014, 11:07 PM
Vararam CAI Installed: Check
Axle Back Exhaust Installed: Check
Still Needed:
SS Fuel Line
Lightweight Skid Plate
Fuel Rail Covers
Headliner Replaced
18" Factory Wheels
BJ
06-05-2014, 09:35 AM
Administrator
Notice any difference with the Vararam? Might need a tune as well.
06-05-2014, 10:01 AM
We really couldn't tell much difference. I was really surprised that there was not any change in the sound of induction like there was when I installed a RotoFab CAI on my 09 G8 GXP. That made such a difference that it also actually increased the exhaust note. We haven't considered a tune but may do so. We're having the headliner replaced next Tuesday. I've learned that this is a common issue on these cars, especially if they sit outside in high heat states like Florida, where this care spent the bulk of its life.
BJ
