Old 12-09-2017, 09:50 PM
68droptop's Avatar
68droptop 68droptop is offline
Default Progress Update
Starting a new progress thread since my other one was taken over about paint
ID:	469751   Click image for larger version
ID:	469755   Click image for larger version
Project "Thanks Dad!"
Old 12-10-2017, 12:56 AM
MD79TA MD79TA is offline
Looking forward to it. Got the same car and always doing work on it. I will pm you my email so we can ask each other questions. Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
1979 400 Block, 1970 Heads, Unknown Cam, Comp Cam Lifters, Edelbrock RPM Intake, Hedman Headers, Holley 750 Carb, WFO Drop Base SOLD
1968 GTO convertable project. 400 auto with air. west coast car . Not started in 15 ..update now running (around block spinning tires all the way. Have a lot of cosmetic work to do winter of 17/18
1969 GTO 400 4 Speed this a complete project. Rebuild will start in spring of 2017. SOLD
Old 12-14-2017, 07:29 PM
68droptop's Avatar
Not bad for the first test fit of the bumper
Old 12-14-2017, 09:06 PM
68droptop's Avatar
Another pic
Old 12-14-2017, 11:26 PM
Is the engine installed? I see your wheels on the ground. I was surprised after fitting my bumper then lifting the car on a post lift how much the gaps opened up. but once back on the ground the gaps were back to normal. FYI
Tom
'68 GTO
'69 Corvette
'75 Cadillac Coupe Deville
TOM
Old 12-15-2017, 01:08 AM
dataway's Avatar
dataway dataway is offline
Yep. The bumper is attached rigidly to the frame, the fenders bolted to the body and the rubber mounted core support will try to stay in place while the frame sags from engine/bumper weight when jacked up at the firewall.
Old 12-18-2017, 09:05 AM
68droptop's Avatar
Getting them gaps right
ID:	470330   Click image for larger version
Old 12-30-2017, 09:27 PM
68droptop's Avatar
I just love working on this bumper lol
ID:	471295   Click image for larger version
ID:	471296   Click image for larger version
ID:	471297   Click image for larger version
ID:	471298   Click image for larger version
Old 12-31-2017, 04:02 AM
dataway's Avatar
Problem is .... looks great ... but too good to be factory. I've never seen a factory Eundura that fit that well
Old 12-31-2017, 09:51 AM
Very nice, two areas to consider;
1... the bumpers had a notch where the hood meets the fender, this created a gap between the hood and bumper (hood should be a bit back from the front of fenders). I suspect this was to allow a bit of movement space when the nose would get bumped.
2...the valence upper inboard of the parking lights is too far out.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 12-31-2017, 06:41 PM
dataway's Avatar
Keep in mind the bumper is bolted solid to the frame horns. The fenders fronts are bolted to the rubber mounted core support ... they move differently, need a little clearance so they don't rub and chip the paint.
Old 12-31-2017, 07:15 PM
68droptop's Avatar
I hear ya bud. Right now I'm just getting it straight and test fitting. I'll leave that little gap later
Old 12-31-2017, 08:29 PM
Didn't the firebirds use a black rubber seal between the fender and bumper? Always thought they should have used on GTO. Would make alignment easier and a cleaner look? i am sure other don't like. Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 01-01-2018, 12:30 PM
Hammertime Mike's Avatar
Hammertime Mike Hammertime Mike is offline
Send a message via ICQ to Hammertime Mike
Subscribed, nice work !!
Old 01-01-2018, 05:39 PM
dataway's Avatar
They used the rubber seal on the chrome bumper Lemans and Tempests ... and yes I personally would have liked to see a bit more gap from the factory. So many of the bumpers (Endura) are messed up right from the factory trying to get them to fit right. I've seen them on 68 with everything from no grinding to clear the hood, to almost a quarter inch notch in the bumper so the hood would go down.
Would love to see the factory process they used to work that out.
Old 01-01-2018, 06:29 PM
Formulajones's Avatar
My memory isn't always the best but I seem to recall the factory assembly manual tells you to raise the car at the firewall during bumper alignment. Once satisfied and everything tight, lower the car and the bumper will pull itself in. I personally don't like this method and prefer to align them with full weight on the suspension, and engine installed.
Yes they do separate from the fenders as the front of the car is raised up. Pain in the butt when you have one making a little power (wheelies) the bumper tends to move around.
I had my fathers bumper aligned perfectly and it's already moved around a bit. Things settle a bit too. I'll have to go back and fiddle with it more.
I agree about the rubber inserts, used on the chrome bumpers. I've seen it done on rubber bumpers (not originally but during a restoration) and while at first I scoffed at the idea because it wasn't correct, it has kind of grown on me. Not enough to make me do it, but if you fiddle with these stupid bumpers long enough you start to see the benefits of those rubber inserts.
Old 01-01-2018, 08:55 PM
I wasn't taking about the chrome bumper but the endura bumper on 69 firebirds. I think between the front of fenders and bumper they used a black rubber seal . I thought it looked cleaner than the GTO . My memories are not what they were so I apologize if I'm incorrect. i can only hope I can come close to those gaps on the OP car. Doug
1979 Trans Am
307 RWHP 380RWTQ
13.8@103
Old 01-02-2018, 10:36 AM
Or is it that the beak of the bumper is pushed in at the bottom? Looks a little pushed in... Otherwise, fantastic fit at the fender contours. Not easy to do.
Old 01-02-2018, 12:58 PM
68droptop's Avatar
I see what you guys are saying....but I don't know why the pic looks like that. It doesn't look that bad standing in front of the car.
Old 01-02-2018, 01:00 PM
68droptop's Avatar
I guess it's a good problem to have
