OHC-6 TECH Over Head Cam projects, questions and advice.
Old 02-13-2020, 01:25 PM
Karl,
To answer your questions about the camshaft & followers, I have never seen damage to a cam follower like you have on the #4 Exhaust follower, it seems to have damaged the lobe some by your picture. Also it looks like most if not all the followers have visible wear on them. Usually when the follower is worn that much the cam lobes are also worn down a like amount.
Another thing to check is the Oil hole from the block to the head, in 1966 and some early production 67 engines they had an issue with the alignment of the pressure oil hole from the block to the head. I have seen it misaligned so less than 1/2 the oil passage to the head matches up to the hole in the bock. It is easy to correct if it is there, I just hand ground the hole so match up, and modified the head gasket to match. This issue caused alot of early cam failures. It was corrected early in the 1967 model production. So not an issue with later engines.
Name:	cam followeres.jpg
ID:	531816   Click image for larger version
  #42
Old 02-14-2020, 03:21 AM
exotec exotec is offline
Hi Jeff,
thank you for your clear explanation!
really appreciate that!
This coming weekend I will finish dismantling the engine and start cleaning all parts and than I'll bring it in the shop.
Kind regards
Karl
serwas
Karl
follow my project on instagram
  #43
Old 03-01-2020, 03:43 PM
Is there a recommendation for a complete clutch for the ohc with a 3 speed Saginew trans?
serwas
Karl
  #44
Old 03-01-2020, 05:53 PM
Hokie1984 Hokie1984 is offline
In Austria I don't know. I ordered the Perfection Clutch kit MU16751 from Rockauto. It was the cheapest one they offered. Bolted right in, pilot bearing was correct, throwout bearing was correct, no issues, Feels good, not too heavy.
  #45
Old 03-01-2020, 07:35 PM
Jeff Hamlin's Avatar
Thumbs up
Any Pontiac 10.5 offerings should work.
I just order mine as a GTO and everything is the same.
  #46
Old 03-02-2020, 04:33 PM
I agree with Jeff, I used to use Hays 10.5 clutch and pressure plates, same as a GTO.
  #47
Old 03-03-2020, 09:12 AM
thank you all.
Luckily the big ones like Rockauto, summitracing are shipping to very reasonable prices to Europe and Austria.
serwas
Karl
  #48
Old 03-18-2020, 01:32 AM
Engine is waiting at the motorshop for detailed inspection to have a list of required parts.
Meanwhile I take care about other parts in the homeoffice.
Intake ready after coating with por15 hightemp spraypaint and 2 hours on my webergrill
serwas
Karl
  #49
Old 03-19-2020, 09:35 AM
Fellow Cammers, I need your support to select the best and correct parts, please!
Piston and rings:
we have 3.905 bore, so it was bored already one +0.030.
Engine shop says it must be bored again to the next available size. So this would be +0.060. correct?
Which piston and ring set of which manufacturer would you recommend?
Connecting Rod Bearing
measured shaft diameter 1.990.
The engine shop advises to further polish the shaft to the next possible oversize. Would this than be 0.020?
Which size would this be? Which bearings and manufacturer would you suggest?
Main Bearing
measured shaft diameter 2.28779.
Valves
are there any valves (intake and exhaust) available with a thicker shaft diameter?
Engine Shop says the guide needs to be rub out/straigned. What would you suggest here?
So many, many questions. But as I need to order the parts in the states, I should have it right in the first shot.
Thank you and kind regards, Karl
serwas
Karl
  #50
Old 03-20-2020, 06:38 AM
As mentioned before your best bet would be dealing with either EGGE Machine and/or KANTER Auto. With my first OHC build many years ago I bought the pistons from EGGE back then they offered .60 so I would check with them first.
Also whenever I have a head re-worked I always have Bronze Guides installed,
I would think this is needed to address your stem issue.
I will also add that VITON seals are great for these engines.
Cheers.
  #51
Old 03-20-2020, 08:40 AM
I have sent an inquiry to Egge.
We will also go for a valve guide and use orig. available intake and exhaust valves.
serwas
Karl
  #52
Old 03-20-2020, 11:00 AM
694.1 694.1 is offline
Oversized valve stems are pretty uncommon, It seems like these were available only to large rebuilders so the universal remedy is to use press in liners to restore valve guides.
Rod bearings are easy, seems like they are the same as Chevy? Widely available.
Mains are OHC specific.
Pistons, I would use Egge only if their cast pistons have steel struts cast in them to control expansion as many of their in house pistons used to lack this key feature.
Jerry Woodland would also be a good source or reference for parts.
Jerry Woodland/Woodland Sports 11361 N 2000 East Richmond, UT 84333.
Still have my 1st Firebird
7th Firebird
57 Starchief
  #53
Old 03-20-2020, 11:32 AM
Thank you for Jerry's name. I dropped him an e-mail.
serwas
Karl
  #54
Old 03-20-2020, 01:13 PM
no pistons on stock and several months for before again on stock
serwas
Karl
  #55
Old 03-21-2020, 03:18 AM
Jerry seems to be a great source of parts and knowledge!!
serwas
Karl
  #56
Old 03-21-2020, 08:48 AM
Jerry has been around these little engines for a long time.
I consider Richard McDonough & Jerry pioneers in-stock aftermarket parts for the OHC 6.
Jerry has come to a point in life where he wishes to pursue other endeavors and is offering the sale of his OHC business.
So if anyone is thinking about some of his items don't wait too long.
  #57
Old 03-22-2020, 05:08 AM
Polished the timing cover I habe got from Jeff!
My quality of work is just a matter of the viewpoint 😉
ID:	534999   Click image for larger version
serwas
Karl
  #58
Old 03-26-2020, 03:43 AM
found the build sheet of my Oldsmobile Omega - it was still under the rear bench seat
serwas
Karl
  #59
Old 03-26-2020, 07:44 AM
The cover looks great Karl!!!!
  #60
Old 03-28-2020, 11:15 AM
just realized that on the pic, before my Olds was loaded onto the ship, there is a DeLorean!!
This must have ended with the Pontiac ohc 6 engine
serwas
Karl
