Old 09-23-2022, 11:20 AM
Default Can anybody decode this DOT date code on a tire?
I thought the DOT code was the last four digits. The first two are the week of manufacture, the last two are the year.
This doesn't look right. Did the date codes change recently?
Mike
Old 09-23-2022, 11:28 AM
gtohurstjudge's Avatar
gtohurstjudge gtohurstjudge is offline
That isn't the DOT number you are looking for......look on the other side of
the tire for the number you need....first two digits of the last four will be the week....last two the year.
Also the number will be right next to the bead of the tire, not way out on the sidewall.
Old 09-23-2022, 11:47 AM
77 TRASHCAN's Avatar
There will be 4 Numerals after the DOT, as mentioned by Mike.
IF, there are only 3 numerals, this means the tire was made before January first, 2000. A very old tire........
Shut it off
Shut it off
Old 09-23-2022, 12:03 PM
einstein's Avatar
einstein einstein is offline
And If it still holds true like in years past, the date code will be imprinted, rather than raised characters. Typically the imprint appears to be in an oval space.
Old 09-23-2022, 12:18 PM
gto4ben gto4ben is offline
I'm glad to see there are some tire experts here. I have what I believe is an original F70-14 Firestone Super Sports Wide Oval redline tire from my 67 GTO. It has no DOT date code other than a serial number V000492R. My question is with regards to the location of the redline on the sidewall. It appears to be much closer to the tread than any of the reproductions I've seen. Coker's, for example, have the redline closer the wheel. Were there any variations of the redline location over the years? If so, can the location help narrow the manufacturing date?
ID:	599217   Click image for larger version
Old 09-23-2022, 12:48 PM
OG68 OG68 is offline
This is the date stamp from my original spare.
1058 (Late April 68).
Car build date 05A
2007 Cadillac SRX
einstein's Avatar
Wow... I don't recall ever seeing a redline out that far, nor white, blue or gold stripes either.
Old 09-23-2022, 01:16 PM
geeteeohguy's Avatar
ID:	599222Here's my original spare out of a '67 GTO. '66 date code. The tire with the outboard redline looks like a recap to me.
This one is a Uniroyal Tiger Paw.
Jeff
The Following User Says Thank You to geeteeohguy For This Useful Post:
Old 09-23-2022, 01:50 PM
Old Goat Racer's Avatar
This mite help
https://www.tirerack.com/tires/tiret....jsp?techid=11
Everybody knows somthin.
Nobody knows everything !
Old 09-23-2022, 02:12 PM
Thanks but my tire had no "DOT" embossed or raised lettering, nor has 10 digits in the serial number as mandated by the DOT in 1971, indicating that it was manufactured prior to 1971. As I look at the redline position, I'm reminded of a tire slogan that said something to the effect, " if it were any closer to the road, it would be a white line." Anyone know which brand had that slogan? It certainly would fit with my redline position.
Name:	serial number.jpg
Old 09-23-2022, 04:13 PM
242177P's Avatar
242177P 242177P is offline
ID:	599238   Click image for larger version
ID:	599239   Click image for larger version
Old 09-23-2022, 08:57 PM
Redpiston Redpiston is offline
I don't recall seeing that interior on pic #2 offered on any sales material.
Old 09-23-2022, 09:58 PM
Jeff Hamlin's Avatar
Thumbs up AUTO SHOW SPECIAL
FUGLY ;-)
Old 09-23-2022, 10:25 PM
242177P's Avatar
Sorry to break it to you, but that's a Day 2 tire. Tiger Paw was OEM in 64-66, but Firestone took over in 67. Uniroyal wouldn't have called it quits, continued selling plenty of Tiger Paws (just not as a Pontiac factory offering). There was an optional 7.75, not familiar with it though.
Naturally. The Surfrider was a mild custom. You're supposed to be looking at the Firestone Wide Oval and where the redline/whiteline was positioned.
ID:	599259   Click image for larger version
ID:	599260   Click image for larger version
Name:	Firestone F-70x15.jpg
ID:	599261   Click image for larger version
Name:	Firestone Mustang.jpeg
The Following User Says Thank You to 242177P For This Useful Post:
Old 09-24-2022, 07:17 AM
Thumbs up
[/url]
[/url]
[/url]
ID:	599269   Click image for larger version
Name:	66 GTO TIRE OP-1.jpg
ID:	599270   Click image for larger version
ID:	599271   Click image for larger version
ID:	599272   Click image for larger version
Name:	67 TIRES.jpg
Old 09-24-2022, 07:19 AM
Cool
Sorry to drift, but I just like those old Tire Ads.
Name:	65 FIRESTONE AD WRONG WIRE CAP.jpg
ID:	599274   Click image for larger version
Name:	67 FIRESTONE AD REDLINE.jpg
ID:	599275   Click image for larger version
Name:	67 FIRESTONE AD BW.jpg
ID:	599276   Click image for larger version
Name:	67 FIRESTONE AD.jpg
Old 09-24-2022, 03:19 PM
Thank you everyone. Based on the print ads and some you tube videos of Firestone TV commercials, the stripe is indeed closer to the tread in 1967.
Name:	Firestine Wide Oval Introduction.jpg
The Following User Says Thank You to gto4ben For This Useful Post:
Old 09-26-2022, 01:29 PM
the redline and whiteline wide ovals only had the stripe that far out
for about 18 months..........in my opinion they stopped putting the stripes
that far out due to complaints about curb damage.
Old 09-26-2022, 02:24 PM
grandam1979 grandam1979 is offline
Also if you look the dot date is a removable insert in the mold for changing the date code. All the pictures except the op’s original picture is a insert.
