1973-77 rear springs
Does anyone know if '68-'72 rear springs are the same as the '73-'77 rear springs? I'm looking to put a set of Moroso trick springs on the back of my '76 Grand Prix and I'm not sure if they are the same.
Thanks in advance. |
Not the same
As far as I know, they're not the same. Get a pair from Summit Racing or Ames Performance from their catalog. Better yet call them and they'll ensure you get the right one.
1974 Lemans Sportecoupe GT (daily driver) "Well the girls out there knock me out, you know Cruisin' around in my GTO" Rock 'n' Roll High School Ramones |
They are not the same, if you are just trying to raise the rear end a bit, I used to put same year El camino Springs in, I tried A-Body Station Wagon Springs once, but they were a little to Stiff of a ride. But the 73-77 El camico springs always worked on my 75-77 GP's.
74-77 should be the same, the 73 springs are a bit lighter as they did not have the 5mph bumpers on the back yet.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
On a side note, if you're looking for another source for springs that will fit our 73-77 A-body, the '94-'96 Impala-SS springs are a direct fit. I installed a Hotchkiss kit on my Can Am at all 4 corners in 2018 intended for the Impala-SS and they were a direct bolt-in.
That makes sense as I was told years ago by a GM Chassis designer that the 77-95 B-Body Chassi was based off of the 73-77 A-Body Chassis. I know for a fact that front Sway bars and front spindles swap between them.
never thought about rear springs though.
I understand other parts are interchangeable as well, such as the steering gearbox. Apparently those 90's B-body frames were just about identical to the '73-'77 A-body frames.
Steering boxes from 1985-1996 Caprice police or Impala SS are a huge upgrade over the original 1970's variable ratio, zero road feel boxes. The Caprice hydraulic fittings are o-ring, but Lee MFG. sells adapters, and the input shaft spline count is different for 1973-76 A bodies, but a direct fit for 1977 A bodies. You will need a different rag joint for those earlier A bodies.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
