1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 08-05-2003, 06:52 PM
dennisk dennisk is offline
rear end has either an HF or NF. Any idea what gear ratio this is. Thanks for the help. Also would this rear fit in a 68 catalina and use the rear sway bar.
Old 08-06-2003, 04:30 AM
grandville455's Avatar
grandville455 grandville455 is offline
try this but i didn't see it listed
http://www.wallaceracing.com/cgi-bin/axle.cgi
Grandville464
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 08-06-2003, 06:39 AM
This is just what we needed! Thanks for the help. I am wanting to use the sway bar on my 68 catalina convertible and had considered a total rear swap as well. Do you know if that will work?
