1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 03-23-2003, 04:20 PM
pontfan pontfan is offline
can some one please help? and tell me any thing about this engine. the block is stamped c367528yn
the heads d141. it is pontaic 350. i greatly appericate any help!
Old 03-23-2003, 06:40 PM
WDCreech's Avatar
WDCreech WDCreech is offline
pontfan, Good for what? A street engine on pump gas? Probably, if your happy with a 350. By the numbers you gave, assuming that the heads are original to the block, it should be a 250hp, 2bbl, auto transmission engine from an "A" body. The number you gave for the heads was the date code (April 14, '71) and they should have a 94 cast on top of the center exhaust ports. They were rated at 8:1 on the 350.
Bill
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
8.2550@164.17-1/4, 5.2901@131.97-1/8, 1.1981-60-ft. 8/10/08
Old 03-23-2003, 08:38 PM
thank you. the engine has been rebuilt its at a machine shop a new owner bought the place and it was already there, rebuilt. i was getting prices on getting my 389 rebuilt when he told me about it. he wants a ddeposit on the 350 before he will take it apart and check the specks on it and types of parts. i am putting an engine in my 85 cutlass supreme. i have a 400 trans and already have a new edelbrock 600cfm carb and preformer intake. im tring to deciede what to do. he wants 1100$ for the 350 long block. or 400$ deposit before he will check it. thank you any help orsugestions will be appericated.
Old 03-23-2003, 10:00 PM
WDCreech's Avatar
That engine in a Cutlass would probably be ok for a daily driver, but with a TH350, in an Astre, Sunbird, or a T-1000, would be a killer street machine!
Bill
Bill
