1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out.
Old 07-27-2008, 10:44 PM
Tom Vaught's Avatar
Boost Engineer
Default Are the headlight doors on a 88 Trans Am vac or electric
Brother has a bad unit. Need to info and a part.
Tom Vaught
Old 07-27-2008, 11:35 PM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
They're electric. I put a new motor in the 1990 Formula we had and had to purchase it from GM.
Old 07-28-2008, 01:25 PM
Cammer-6 Cammer-6 is online now
most of the problems are from the gears stripping
take apart and flip the gear over and its fixed until the next time it strips
the headlights have a controller so may want to check that too
Old 07-29-2008, 03:41 PM
stimpy stimpy is offline
there is a guy on the ls1 tech board that sells a aluminum replacement gear thats not that expensive , the replaement motors go upwards to 200 bucks
Old 08-02-2008, 02:16 AM
Bull's Avatar
Bull Bull is offline
Lon at Top Down Solutions has an inexpensive nylon fix that will take care of some of the lazy headlight issues.
IIRC, there is alos a relay on the firewall that affects their going up and down, but I'd have to look for the specifics on that.
