Old 08-08-2023, 02:28 AM
455-4+1's Avatar
455-4+1 455-4+1 is offline
Default 76 455 TA carb
Is anyone able to post a few pics of their factory 76 455 TA carb linkage.
Any engine pics without the air cleaner would be helpful also.
I have searched the carb and it looks like the number is 17056261 for an 800cfm with APT.
I have one pic off the net, that shows a fairly simple linkage, as it's for manual trans, the only option, so would not require kick down etc etc.
Just wondering if it is correct.
Reason is, I can't find factory carb over here in New Zealand, but have several Buick from 76 which are close except for linkage. Hopefully I can swap one in and replace primary linkage when rebusing throttle bore
Working on going faster (and now staying dry at the same time !!)
Old 08-08-2023, 02:35 AM
455-4+1's Avatar
To think of it, that pic may be wrong.
Here's a few that might be correct ?
ID:	617627   Click image for larger version
ID:	617628   Click image for larger version
Old 08-08-2023, 08:05 AM
jpg69bird jpg69bird is offline
I had been searching for a 17056261 for years. There were comments on the forum that the carb doesn't exist. The carb on my 76 455 is a 17056263 and was told it was original (always believe what a seller tells you, lol).
I have a spare original 6263 that I can take pictures of, but I won't be able to for a few days. If nobody else comes through by then, I'll post them for you.
69 Firebird Conv, 350 HO w/3 on the tree swapped to Tremec 5 Speed - Sold
72 GP, 400 Auto - Sold
09 G8 GXP M6 Orig Owner - Sold
76 Trans Am 455, 4 Speed - Current
Old 08-08-2023, 04:25 PM
455-4+1's Avatar
Awesome, thanks for that
Old 08-08-2023, 08:31 PM
455-4+1's Avatar
OK, have searched up the 6263 in lieu of the "infamous, possibly missing, possibly never was 6261" and found plenty of pics
Looks like the linkage was pretty common one in my later pics.
I will head in this direction unless something comes up different
Apparently only difference between man and auto of them was ported vac advance provision for Man cars ?
Old 10-26-2023, 07:57 AM
Kenth's Avatar
Kenth Kenth is offline
I guess the 17056261 never got into production since it canīt be found in the Delco Parts&Service #9 manuals.
1976-78 Pontiac M/T Qjets has .038" idle tubes and .110" idle bypass air in the throttle plate add to that about .092" from the hot air choke channel, were the A/T units got no other idle bypass air than .092" from the hot air choke channel and .031"-.035" idle tubes depending on year and application.
Depending on vacuum control system used some got a ported source and others not.
Name:	17056261 ghostcarb.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
