Old 09-19-2024, 08:27 PM
bodee21 bodee21 is offline
Default Set tension on seat belt retractor ?
I took the driver's side seat belt tensioner apart, to install a new cover on my 72 Lemans. What is the secret to setting the correct tension?
Old 09-20-2024, 02:01 PM
I have found the error of my ways! Somehow upon re-assembly of the retractor, the spring got messed up. I was able to cut the bad part off of the spring and bent the end, to fit into the white plastic cap. After 2nd re-assembly, I was able to set the tension that I needed.
The Following 2 Users Say Thank You to bodee21 For This Useful Post:
Thread Tools
Display Modes
