Old 11-20-2020, 03:10 PM
72projectbird's Avatar
Default Parting out 73 Formula
I have a 73 Formula 350 4 speed I'm cutting up. It's pretty rotted, missing the driver quarter, and took a pretty nasty hit that bent the subframe and firewall. I took the dash for my other car, but has pretty much the whole interior still. Still has the pedals and floor hump.
If you need anything off it let me know. I'll be chopping it up shortly.
I do have a clear title for it.
Located in N.E MA
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 11-20-2020, 08:45 PM
kencar62's Avatar
kencar62 kencar62 is offline
Is any of the 5MPH "crash steel" usable? I'm converting my '73 to use the '71-'72 brackets to remove the extra weight. But, the lower reinforcement part is necessary for mounting the grill brackets. I can cut the portions that I need & attach with existing mounting holes and throw the rest away. It will still add a few pounds, but nothing like the entire structure (~85 lbs).
Old 11-20-2020, 09:03 PM
Bob71400 Bob71400 is offline
I could use the seat tracks if they are good. Also does it have a factory radio?
Thanks,
Bob
Old 11-20-2020, 09:42 PM
nas t eh nas t eh is offline
I don't need them, but If I was you I'd cut out the rear sway bar perches from off the frame, hard to find piece if you need it. I'd be tempted to hang onto the 4 speed items too, but at least that stuff it reproduced// available
Old 11-20-2020, 10:38 PM
Sorry, those brackets are toast.
Thanks,
Bob
I'll check on the tracks tomorrow. If the ones in this car are no good, I know I have a couple extra nice sets.
Good idea! I'll be stripping it down to basically a bare shell before it goes off to become soup cans.
1987 Grand National
Old 11-24-2020, 09:25 AM
Brad Pringle's Avatar
Brad Pringle Brad Pringle is offline
I would be interested in any of the 1973 intake manifold vacuum fittings? should have a two and three port vacuum fitting both on the front of intake. Condition of the seat belts? Is the alternator dated 1972 or 73? Are the vavle covers Drippers? Drop me a text at 9064409257 Thank you
Brad
Brad Pringle
Wellston, Michigan
1973 SD 455 TA Auto
1974 SD455 TA 4 Spd
Old 11-24-2020, 11:23 PM
sent you a PM
Old 11-25-2020, 02:14 PM
Brad
The engine in it is out of a 75 I believe, so I dont think anything on it will be the correct date. I'll double check to be sure.
1987 Grand National
Old 11-26-2020, 10:03 PM
Pepi's Avatar
Pepi Pepi is offline
Happy Thanksgiving!!
How about the master cylinder? Does it appear to be original with the bleeder screws? I would be interested in that.
Do you have all the rims for it including the spare? Would be interested in those if you could give me the date codes.
Thanks,
Karl
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
Old 11-27-2020, 03:57 PM
Thanks,
Karl
I have a member currently interested in the master, but if it falls through I'll let you know.
I don't have the original wheels.
1987 Grand National
Old 11-27-2020, 05:50 PM
unruhjonny's Avatar
unruhjonny unruhjonny is online now
What's that \/ (circled in red)
That curious bracket got me thinking a little more about other small brackets;
I might be interested in little cable retention brackets (ect) that were used to route and hold the wires going to the starter if any are there - I don't believe I have any at this time.
Also!
Out of curiosity, what's the top of the steering box look like?
I believe I tossed the one I bought my car with decades ago, there's nothing wrong with the box it currently has, but maybe the aluminum top on yours might be of interest to me
http://www.camaros.org/suspen.shtml
Name:	73 W66 parts car.jpg
1970 Formula 400
Old 11-27-2020, 06:52 PM
formula kid formula kid is offline
What about the front bumper? Don't need the header.
Old 11-27-2020, 10:10 PM
Pepi's Avatar
What about the original jack assembly?
Old 11-28-2020, 02:28 AM
I have a 73 bumper. Needs a little work, but not bad.
Original jack is long gone.
1987 Grand National
Old 11-28-2020, 10:06 AM
HoneyHush HoneyHush is offline
I sent a pm to you about some sheet metal parts I’m looking for. Sometimes they don’t go through I guess. Can you call or text me at +18593608421
Old 12-01-2020, 01:29 PM
LeGoaT/As LeGoaT/As is offline
P.M. sent.
Old 12-01-2020, 04:21 PM
455HO75 455HO75 is offline
I am looking for the vacuum line harness assembly from the controller under the dash. I need one for an AC equipped car
455HO75
Old 06-02-2021, 07:51 PM
amdrewmcqueen amdrewmcqueen is offline
Default do u have the stock radio
do u have the stock radio 480 717 8088
Old 06-11-2021, 04:23 PM
lovedemnewfies's Avatar
lovedemnewfies lovedemnewfies is online now
Any chance the rear tail light harness is there?
Old 06-11-2021, 09:02 PM
Ram4king's Avatar
Ram4king Ram4king is offline
Front seats available?
