Old 06-17-2008, 06:41 AM
jhealey1967 jhealey1967 is offline
Default 1957 Oldsmobile/1957 Pontiac Rear Axles—The same?
I've found a rear axle for sale out of a 1957 Oldsmobile that I'd like to put into my '55 Chieftain. It is my understanding that a '57 Pontiac axle is a drop in conversion for a '55. It is also my understanding that Pontiac's and Oldsmobile's shared the same differential/3rd member from '57 to '64. My question is—did they also share the same axle and axle housing? Or at the very least, did they in 1957? Same axle width, spring mounting, shock mounting, e-brake mounting on the backing plate, etc.? Any help would be much appreciated.
Old 06-17-2008, 09:40 PM
radioburningchrome's Avatar
radioburningchrome radioburningchrome is offline
According to my 1950-1965 GM Interchange manual, the axle shaft for Pontiac fits only 57-58.The differential case interchanges 1957-58 Pontiac and Olds. Ring and gear interchange Pontiac and Olds 1957-63 w/ 3.08, 3.23, 2.87, 2.69 and Pontiac 61-63/ Olds 62-63 2.56.
FWIW the interchange also states differential case interchange for Pontiac/Olds as:
53-56
57-58
59-63
Old 06-17-2008, 10:36 PM
Pontirag Pontirag is offline
axle assemblies do not interchange between olds and pontiac
in 58 both olds and pontiac went to coil springs. So 57-58 dont interchange either.
My interchange book states that the rear ends for 55-56 pontiacs dont even interchange with 57 pontiac either.
Ford 9 inch !!! It even looks the same at a glance. PM me and I can tell you what to look for and to look out for.
Old 06-17-2008, 10:53 PM
What interchange do you have?
Old 06-18-2008, 09:00 AM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
If it's the same total axle width-about 60 1/2", it can be made to work. The spring perches can be added on, the shock bolts to the bottom leaf spring plate so reuse those. Also the housing end bolt pattern is the same so use your 55 backing plates also if the olds is differant.
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 06-19-2008, 11:38 AM
Auto Interchange Systems,
1950-1965 Gemeral Motors Interchange Systems
3211 Robinwood Lane
Minnetonka, Minn.
55343
Published in 1979
Old 06-21-2008, 11:27 AM
Is that different from the General Motors?
I have the same manual printed in 1979, but the address is different:
4048 Velarde Court
Las Vegas , Nevada 89120
Is it possible I have an incorrect version? It has a light blue cover, white spiral bound and a total of 230 pages.
Old 06-21-2008, 12:12 PM
Mine is green cover staple bound complements od J C Witney. Dont know the no of pages as it just got packed
mine has a few mistakes in it too. like 292 chevy six intake interchange info. price info is interesting reading
