Old 01-13-2004, 09:19 AM
stuman stuman is offline
i have 2 sets of #46 heads from a '73 350cid pontiac i would like to know the maximum ammount of material i could remove in the spring seat area. would .040in bee too much? (trying to get to a 1.700in installed height (measured 1.660 currently).
Old 01-13-2004, 11:30 AM
John Bailey (GTOKID)'s Avatar
John Bailey (GTOKID) John Bailey (GTOKID) is offline
remove nothing, get a .50 up retainer and or longer valves. if heads are ported you do not want to remove anything from spring pockets. Its the best way.
Old 01-13-2004, 11:45 AM
heads cannot be ported (against rules)
i have a cutter ready but needed to know what would be too much.
Old 01-13-2004, 12:22 PM
Steve Barcak's Avatar
I've cut many heads myself, some well over .050" without any problems. When cutting alot, your seat pressure could be an issue but, it shouldn't be a problem. Steve www.pontiacheaven.org
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 01-14-2004, 03:45 PM
Dennis B Dennis B is offline
stuman. Is there any particular reason you're using # 46 heads?
www.pontiacfever.freehomepage.com
Old 01-14-2004, 04:00 PM
tikiklubracing's Avatar
tikiklubracing tikiklubracing is offline
If he has a 69 428or a 73 350 and there was mention of race rules, this is his only option for the 69 or 73, right!
"Somebody sell me a 78 Catalina grille, please",15 yrs in NHRA tech ret. 413 rpm 4150 3.73 hoosiers 13.54 4050# Winter Sucks www.nhra.com www.ihra.com
NHRA tech.
"Its just a 412, I swear it".
Pontiac tip of the year, quit those damn cigarettes.
Old 01-15-2004, 06:05 AM
the #46 heads came with the engine, and i have no others available.
purchased 2 - 1973 350 pontiac engines and one set of heads had large shouldered screw-in rocker studs and the other set had push-in studs.
right now i'm rebuilding the first set (screw-in) as practice, then i'll rebuild the second set for the engine i'm building.
see previous post on imca dirt track racing.
Old 01-20-2004, 11:50 AM
one last question -
would it be advisable to pin the rocker arm studs?
cam - 246/246 duration at .050 cam lift - .345
how about information on a lifter vally stiffener
Old 01-20-2004, 11:20 PM
STripleduce's Avatar
STripleduce STripleduce is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>purchased 2 - 1973 350 pontiac engines and one set of heads had large shouldered screw-in rocker studs and the other set had push-in studs.
<HR></BLOCKQUOTE>I would've saved the screw in stud head for the build.
http://community.webshots.com/user/stripleduce
Old 01-21-2004, 09:43 PM
Paul Spotts's Avatar
Paul Spotts Paul Spotts is offline
Stu
If you already have the stock length valves, its best not to machine the spring pads. No one can tell you how far you can cut because it depends on the condition of the inside of the head where the coolant is - the part you can not see.
You can use the crower 68404 springs that install at 1.600 for a hydraulic cam. I'm assuming your trying to install a set of comp cams 995 springs?
Do not pin the studs - have a machine shop tap and install 7/16 heli coils for screw in studs.
The 73-74 #46 heads are very good low compression heads - I like how they do not have the exhaust port bumps like the 6X heads have.
www.spottsperformance.com
East Coast Pontiac engine builder - still going strong
4 month waiting list
email spotfam@verizon.net
1981 Trans Am 455 w/6X heads 4 speed 4 wheel disc (for sale)
1969 Trans Am clone 9.79 at 139 so far
1964 Banshee clone project - Opel GT platform
Old 01-23-2004, 06:12 PM
the rules won't allow the use of shoulderd screw-in rocker studs. that is why i was grinding valves and dressing the seats in that head first(as practice).
This 1.660in measurement comes from the use of a chevrolet valve springs (z28) and chevrolet valve spring retainers. I'm using these valve springs just to save money. yes i can buy new springs, but we have lots of z28 springs laying around for use.
the only offset valve retainer i have found uses 10deg locks, i cannot find one that uses the stock 7 deg angle.
Old 01-25-2004, 07:37 PM
crower has the 7 degree retainers with additional heights incorporated, but you may run into problems with rocker contact if the tip length is not tall enough. I'm direct with crower if you need anything.
If you need to run low compression pressed in stud heads the casting #66 heads used in the 1971 455 is a large valve head (2.11/1.77)
Another great candidate for a blower motor
