Old 10-13-2003, 10:27 PM
CW67 CW67 is offline
I have looked at several water pumps for 67 gto on the inter net to purchase, if looking right at the fins of the inpeller I have seen the fins going in one direction on one and the other direction on another. does anyone know which way the fins should go? I would not want to purchase one with the fins the wrong way. thank you
Old 10-14-2003, 10:50 AM
JoeF's Avatar
JoeF JoeF is offline
I don't recall for sure which way the fins go, however the most important thing you need to look for in a water pump is a cast impeller, not stamped. If you do a search in this forum, there is a lot of good info on water pumps. Some good pictures too.
'67 GTO Conv 400 TH400
Old 10-14-2003, 11:29 AM
STripleduce's Avatar
STripleduce STripleduce is offline
This is a pic of an 11 bolt pump but the direction of the vanes is the same that you would want.There is a thread on the board somewhere about a company that was producing them with reverse impellers,I think it was in the lobby.As you can see the cast impeller is more quality peice.
http://community.webshots.com/user/stripleduce
[This message was edited by STripleduce on October 14, 2003 at 03:03 PM.]
Old 10-16-2003, 12:28 PM
Bill H's Avatar
Bill H Bill H is offline
This is the part number for a rebuilt cast iron water pump for 64-68 V-8's, put one in my 67 GTO.
Part number : A1 Cardone 58299
I got mine at Kragen Auto., availabe on their website also.
67 GTO HT
1968 400 Engine YE
TH-400
#13 Heads -J069
Q'Jet .
8.2 Eaton Posi/3:55
