Hi guys,
I am looking for a new complete ignition system for my Pontiac and was wondering what you guys recommend. Car is a 65 GTO, 400 30 over, about 13 to 1 compression, Lunati solid flat cam around 540 lift, E-Heads. Looking for suggestions for Distributor, Coil, Plugs, Wires etc. Thanks in advance for all the help. Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi. |
Hi guys,
I like the MSD Billet distributor with the 6 or 7AL and the Blaster coil. I also use the MSD wires. 5 years--no problems...knock on wood.
fasteddy |
What fasteddy said. 6AL if you are street / strip. 7AL if strip only. Can't go wrong. Tried and true.
1964 GTO 501, Edelbrock Heads NA, 3460 lbs. 9.76 @ 137mph 1971 Trans Am Lucy Blue, 11.56 @ 115 1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112 1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159 2009 G8 GT |
"Take your time, don't live too fast, troubles will come and they will pass... |
You got it for sale Rashionality?
I've been an MSD fan for years. I'd go with the 6AL, Pro Billet dist, and Blaster 2 coil with that set-up. Hey, that's what I've got too :-)
Mike M
Midwest Muscle Machines, LLC .... '68 GTO Convertible plus others |
Go Digital.................Crane (hi-6), Accel (300 plus), or Mallory have really good Digital systems and they are the same price as an MSD 6al system. MSD 6al & 7al systems are so ten years ago! It's like buying a TV with tubes in it.
I have replaced two digital systems with MSD units so far this year. Reliability sucks.
I run std HEI with Proform rebuild kit, and Accel module.. Why??? Cause every one in the tiki klub pits have lost a box at one time or 2 or even 3 times. What made me decide was when one of my best friends, who calls himself the "Finish Line Assasin" Chebbie Camaro, lost one at the ET finals in Indianapolis 3 yrs. ago. I've had HEI to 6200 rpm no problems. "If it dunt make it go faster, then why do we buy em". Consumerism I guess.
NHRA tech. "Its just a 412, I swear it". Pontiac tip of the year, quit those damn cigarettes. |
I rn & reccomend Mallory products. My Mallory box which is similiar to the 6al box is over 10yrs old & works fine. Nno chips needed the rev limiter is built right in. Mallory has a nice digital box out now that i would like to have.
I think Mallory make some nice Digital Boxes myself. Before I bought my Accel 300 Plus system I was going to buy the Mallory Hyfire VIIC system. A very Kick Butt system!
One of the main reasons I use MSD, aside from reliabilty, is --If you do lose a box, which box do you think is more liable to be available as a loaner at the track? Mallory? Digital Fireball XL5 --nope. I don't know for sure but I would think at least 85% of racers use MSD whether it be marketing hype or not.
fasteddy |
If my box goes i just pull the plug & keep on racing.
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Erik W:
You got it for sale Rashionality? <HR></BLOCKQUOTE> YUP
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Scott Esterle:
If my box goes i just pull the plug & keep on racing. <HR></BLOCKQUOTE> Scott, why have it then? LMAO Just extra weight--guess I will agree with HIS-why have any box at all? .
fasteddy |
Extra weight..................you got to be kidding?
"I run std HEI with Proform rebuild kit, and Accel module.. Why??"
Tiki, they will NEVER understand Low tech.
"For some reason a glaze passes over people's faces when you say "Canada". Maybe we should invade South Dakota or something." |
