Old 06-17-2004, 02:20 PM
63 455 GRAND PRIX 63 455 GRAND PRIX is offline
what compression would i have with #16 on a 72 455
Old 06-17-2004, 02:29 PM
If it's the early 400 heads,about 11 to 1 cr.
If it's the SD heads about 8.4 to 1 cr.
Old 06-17-2004, 07:38 PM
Tim Corcoran's Avatar
I have 16's on my 455 and it has 12:1. Course mine has a 4.21 bore and a 4.25 stroke, and the heads may have been milled a tad, and only has 2 valve reliefs on top of the pistons unlike the Seal Pro pistons. If I zero decked the block I'd probably get about 12.5:1.
Tim C
Tim Corcoran
Old 06-17-2004, 09:07 PM
68MeanVerdoroGreen's Avatar
68MeanVerdoroGreen 68MeanVerdoroGreen is offline
I'm using #16 heads on my 455 and used Keith Black Hyperutectic dished pistons to accomplished a pump gas friendly 9.49:1 CR. I can provide part #'s for these pistons if your interested in my build up.
Regards,
Larry Metzger
Columbus, NJ
1968 GTO Verdoro Green Hardtop
1969 GTO Palladium Silver Hardtop
1969 Judge Carousel Red Hardtop X 2
Someday We'll Look Back On This And It Will All Seem Funny.
From Rosilitia, Sung By Bruce Springsteen, CIRCA 1973
Old 06-17-2004, 10:41 PM
SupergasDil's Avatar
68, That is a great picture. You have some beautiful cars. Then again I'm partial to 69's
Old 09-24-2022, 08:55 AM
umpire54 umpire54 is offline
Regards,
Hello, I’d be interested in the p/n’s of the pistons if you still have it.
Thanks,
Monty
Old 09-24-2022, 09:07 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
There’s also a 1970 small valve 16 head.
Old 09-24-2022, 09:33 AM
25stevem's Avatar
25stevem 25stevem is offline
If your 16 castings are pressed in rocker stud with the 1.96/ 1.66 valves sizes then the chambers are way more like 75 CCs, not 72 if they have not been milled any.
If they are pressed in stud then you want to stay away from cam lifts of over .450” at the valve.
This is for two reasons, so you don’t pull the stud out and due to the stock coil bind spec of the valve springs.
I do stuff for reasons.
Old 09-24-2022, 11:22 AM
Jim Moshier's Avatar
Jim Moshier Jim Moshier is offline
Steve,
I have some 1970 16 heads and I cc them at 78 and you can pull pressed-in studs and tap for the 7/16 studs, can't you? If you put new valves 1.77 and 2.11 I am sure it would be closer to 72cc
Jim
Jim Moshier
1971 Grand Prix 462ci SD Performance 6x heads
1962 Catalina 389
1968 Firebird 400-455 I haven't decided
"If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan
Old 09-24-2022, 11:43 AM
25stevem's Avatar
Yes, if he has pressed in studs they can be yanked like a bad tooth and then they can be drilled and taped for screw in studs.
Old 09-24-2022, 11:55 AM
Hikin Mike's Avatar
Thanks,
Monty
That post was 18 years ago and the OP hasn't been here since 2005.
- Mike
