hello guys! i have a gto 71 400 cid no ram air engine;and my drivers side exhaust manifold cracked ; must replace it as soon as possible! somebody can tell me wich header you recommend by experience! |
I think Doug's Headers are the best. They bolt on, don't leak, provide superior ground clearance, improve your performance, and look good. www.dougsheaders.com
You can purchase Doug's Headers from Ace at Pacific Performance Racing, 310-832-4596 or at Performance Years. Both companies will have them in stock for immediate shipment. I have had my Doug's Headers on my '65 GTO for over two years now and I love them.
Due to the current economic conditions...the light at the end of the tunnel has been turned off. Meet you at the finish line.....don't be late! |
thanks ron! BUT DOUGS HEADERS THEY ARE TOO EXPENSIVE ineed to know about less expensive one |
Did you call Pacific Performance Racing to see what the price is?
ron i did not found any headers at "ppr" sorry thats the first time i check for headers! |
I can tell you for certain that he has Doug's Headers in stock. I was there today and will be there tomorrow to observe a friend of mines motor on the dyno. Give him a call tomorrow morning after 10:00 AM and check the pricing. You might just be suprised.
Dougs are the ONLY way to go. They are way easier to bolt on than any other header that I have ever tried. I couldn't believe how great they fit. If not go with any other brand. From my experience they all fit about the same. They are kind of a hassle to install but functional.
dougs, heddman, hooker , flowtech in that order best to least but all will do the job.
72firebird 3800# 496 316cfm eheads, 11.1:1 compression, custom solid roller, victor 4500 intake port matched, 1050 dominator, continental converter flash 4400 stall. 3.73. 2 inch headers with 3.5 with x to mufflers reduced to 3 inch full exhaust. mallory 250 fuel pump, cal tracs with split monos ..Pump gas 91 octane. |
thanks a lot issach428! you anshered my question;so i decided to go with hookers headers p/n:4901-1 with ceramic coating and reducer 3 po to 2 po 1/8 p/n:11030 to connect to exhaust pipe. all for 360$! i hope my choice is not to bad? |
Word of advice if you decide on Hooker Super Comps. They look great, fit well etc, but put studs in not bolts. they are PITA to install with bolts. I had to get the 10 year old kid from next door to start two of the bolts
24 beer in a case. 24 Hours in a day. Coincidence? I think not. " Steve Wright" |
dougs by far, just installed them and they fit great, keeps my x-pipes tucked up too
ok, i bought a set of the cheapie summit headers, and i had a royal pain in the ass getting the bolt in on the passenger side right behind the no.6 cyl. are all pontiac headers this hard on this particular bolt? i ended up getting a bolt with a 3/8 head instead of 7/16.
NO! Doug's Headers fit great and are easy to install.
i bought some Hooker supercomps and hated them, need to fine tune it with a big ass hammer, the passenger side hung down lower than the drivers side, and low enough to scrape stuff and eventually ruin them...i put stock one back on now as i am saving up for some dougs.
Vic in SoCal. Follow me on Instagram- Cloud9orbust 66 GTO clone, 467 cubic inches of Turbocharged Multiport Fuel Injected fury twisting a TH400 into 3.90's wrapped in a 12 bolt posi. My T56 Install My Turbo Build My Vortech Supercharger Build Hyd Throw out bearing Misc Build Pics May the Karma Gods meet you half way.... |
Hooker Supercomps were are real PITA on my 66 GTO. Next time it is Dougs for me. After all, how much is Blood, Busted knuckles and 8 hours of cussing worth?-JimT
