Where do I find a listing of Qjet part numbers?
For Pontiac cars the service manual is a good source for numbers and their applications.
Not sure what you mean by Q-Jet part numbers.
If you mean application by carburetor identification number, there are some listings on the internet (including ours). If you mean listings of the parts for individual Q-Jets, then you need either the Pontiac Master Parts catalog (for Pontiac) or the Rochester Master Parts book (covers all Rochesters). Both cover from 7 to 10 years prior to the print date of the book. Jon.
"Good carburetion is fuelish hot air". "The most expensive carburetor is the wrong one given to you by your neighbor". If you truly believe that "one size fits all" try walking a mile in your spouse's shoes! Owner of The Carburetor Shop, LLC (of Missouri). Current caretaker of the remains of Stromberg Caburetor, and custodian of the existing Carter and Kingston carburetor drawings. |
Pete McCarthy's book has alot. NHRA tech is online and has some also.
