Old 01-20-2005, 10:47 PM
form406's Avatar
form406 form406 is offline
i know the it can take standard 455 pistons...thinking of using the 455 crank in a 400..have lots of forged .30 over 455 pistons...
'74 formula 400, w/shaker (3 scoops) black deluxe interior, '70 406 balanced assembly, .30 trw slugs, moly rings, 4x heads 2.11/1.77 stainless valves, ra 4 cam, e-rpm intake, holley 750 vac. sec, msd hei, hooker headers w/ dual 3'' flowmaster 50 series ending at axle, t400 w/ GM6 convertor, transgo shift kit, b&m starshifter, 3.08 gears, centerlines, 265/50-15 bfg's rear and 235/60-15 front...yes im over cammed but it is still very fun...
form406's Avatar
Old 01-20-2005, 10:58 PM
WDCreech's Avatar
WDCreech WDCreech is offline
That would require the 400 block to be bored .060. Yes it can be done, but it would be advisable to have the block sonic tested before boring. some bocks can go more, but I've seen a few that it would be risky to bore that much.
Bill
64 GTO, tube chassis w/606" IA tall deck, PG & a pro geared Fab 9". 2750 lbs.
8.2550@164.17-1/4, 5.2901@131.97-1/8, 1.1981-60-ft. 8/10/08
Old 01-21-2005, 04:50 AM
PONTIAC DUDE's Avatar
You will not have a problem as long as it's a pre 75 block. After that then you might need to check for wall thickness. But for 99% of street applications, not an issue. Application determines a lot of things. Going from .030 to .060 is only .015 around on each side difference.
Racing, rpms, high compression, then that's a different story. Built tons of 400 .060 and never had a wall issue for street applications.
Old 01-21-2005, 10:12 AM
form406's Avatar
thank you...heard i might have to grind the block to get the 455 crank to clear...just checking my options...
wd creech...i was in anchorage a few months ago...awesome place...played the egan center...the kids were off the hook crazy...
Old 01-21-2005, 10:04 PM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
When I put a 455 crank in my 400 block there was one spot that had to be ground. It was in the front. If I remember correct it was on the RH side with the block upside down.
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
Old 01-22-2005, 12:44 AM
Colin's Avatar
Colin Colin is offline
Location: The ObamaNation we once called the United States of America
Jeff is right.....the front counter balance wont clear...minor grinding required.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."- General George Patton
"Perpetual peace is a futile dream."-General George Patton
"I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them."-Thomas Jefferson
"Any society that would give up a little liberty to gain a little security deserves neither and will loose both."-Benjamin Franklin
Old 01-22-2005, 12:57 AM
Rashionality Rashionality is offline
Using the 400 crank...What about piston pin height from change in stroke, won't the block now need to be decked too or the piston will be down in the hole...right?
"Take your time, don't live too fast, troubles will come and they will pass...
Old 01-22-2005, 02:07 AM
GTODave GTODave is offline
To make up the piston pin difference, I used, if I remember correctly, 6.855" rods in my 400. I wouldn't think you'd be able to deck a block that much to make up the differnce, but I don't know for sure.
Dave
Old 01-22-2005, 07:44 AM
All block are the same height. All Pontiac rods are the same length.
Just use the proper piston for the stroke your using. Pin height.
Use roughly 10.220/10.230 as a deck height.
455 crank: (4.210) cut to 400 size. 3"
Dude main bearing conversion kit.
Pontiac rods: (6.625)
455 pistons: (1.497/1.480)
You can then Deck block for deck height ya want too.
Old 01-28-2005, 03:54 PM
cgeise's Avatar
cgeise cgeise is offline
FYI -- I have a nice set of std. forged 455 pistons set up for floating pins if you need some.
