I am looking to install an Electric Fuel Pump in my 1967 LeMans,455. This is a daily driver. Please give me your opinions.
If it's a stock or mildly modified engine, the Carter #P4594 works very well. It produces 72 gph and 7 psi. Also, the Mallory #4110 is a very good electric fuel pump. At 110 gph and 7 psi, this pump can support more horsepower than the Carter. Neither pump requires a fuel pressure regulator, which makes installation easier. They're both reliable and fairly quiet -- the Mallory probably wouldn't even be heard at all with the engine running. Hope this helps!
"My car would be fast if it had an engine, transmission, and rear axle in it."
"Q: What's better than winning a gold medal in the Special Olympics? A: Not being retarded." |
Ponchopete's choices are good but i've experienced problems with the rubber components "swelling" on the Carter pump. After two went bad, I switched to a Holly with a regulator. Neither the factory or I can say why. Don't forget to install a rollover switch just in case.
Why are you putting one on it?
75bird 7.41 1/8mile at 92mph street car 73Ventura 11.88 at 113 streetcar 69GrandPrix 12.64 at 107 tow car 65GTO 10.14 at 129 tri-power dragcar |
