I currently have a 67 Le Mans @ 3800 lbs w/ driver and fuel w/ the following combo: 455 w/ 400 crank, stock rods, TRW's, cleaned up 6x heads, Holley Street Dominator, old 930 Holley 3 barrel, .525/.540 Comp Cam solid, Hooker 1 5/8 headers, I believe. 9.5 to 1. Turbo 400, 12 bolt w/ 4.11's. I would like to upgrade the iron heads w/ aluminum, as well as step up the cam, and possibly the intake and carb combo. 91 octane, Track car that sees weekend street duty...
Suggestions? Thanks in advance...
67 Le Mans, 3800lbs, pump gas, iron heads, 11's on the motor, ???'s on the juice. |
455 w/400 crank might be your biggest problem!
![]() Do you mean 400 w/455 crank?
Darin '64 Bonneville Wagon (sold) 69 Lemans-All motor (sold) 9.81 @ 136.39MPH |
...11's with a Pump Gas 400 motor. Don't change a thing.
What 1/4mile tire diameter? Full exhaust? What Total Timing Advance???? What Rocker Arm ratio? Change only 1 item & measure the track result. No juice for you...it will bust. HIS
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
I agree with H-I-S, if you are running hi 11's with 413ci, you've got that thing dialled in pretty good. If you decide to do E-heads you'll pickup from the loss of weight. To see any real change do some port on them, get a bigger intake and put a little more gear 4.30. You'll probably spin it a little higher. Watch out those rods are scary above 5700.
Or you could enjoy what you got and save to build a complete new big combo, Not just cubes but induction with a solid bottom end. |
A little larger primary header would help. I used the 1 5/8 Hookers for 2 seasons then went to 2 inch Hedmans and picked up 3 tenths and 4 mph.
fasteddy |
Fast Eddy, I have the 1 5/8 inch headers with 2 1/2 exhaust. My combo: 461, 16 heads ported to flow 250, 274XE, 800 dp, 9.4 comp, RPM intake, 400 th with 10" 3.3k stall, and 3.25s. I am going to upgrade to bigger headers (1 3/4" or 2") and 3" X-Pipe to the 2 1/2" mufflers. What is your combo like? I am interested to see how much I would pick up.
GJN 1968 Firebird 400 461 3,580 LBs 3.2k Stall 3.25 1.657 - 60' 11.637 @ 115.45 http://www.youtube.com/watch?v=dEqzw...e=user&search= |
lol, it was late last night...
It is a 400 block w/ a cut down 455 crank. H.I.S., 28x10's, 3 1/2 Flowmasters that dump right before the axle, 1.65 HS's
Step up to a 1 3/4" or 1 7/8" header primary dia. Othwerwise, I leave it alone until you up the cam and heads.
Have A Great Day |
