Old 03-25-2005, 11:08 AM
Bill Hanlon's Avatar
I equipped my 57 GMC (with from the factory 347" Pontiac V8) with a junkyard HEI from a '77 400 Pontiac. I've seen HEI caps at car shows that have the connections re-routed internally so that the plug wire connections point directly at the plugs, eliminating the "can of worms" effect near the distributor.
Some have referred to these as "crossfire" caps, but my Google searching for "crossfire HEI cap" has yielded nothing but specs for regular caps.
Three questions:
1. Does anyone know the correct name for these caps? Maybe the manufacturer's name?
2. Does a Chebbie HEI cap interchange with a '77 Pontiac HEI cap?
3. This engine is NEVER spun over 4000 RPM. Anyone heard of any problems with these caps in daily driver use?
Three questions:
Old 03-25-2005, 12:04 PM
The standard Chevy and Pontiac caps are the same.
The one you're talking about probably wouldn't be.
The Pontiac rotates Counter-Clockwise.
That cap is probably wired for the Chevy rotation - clockwise.
Old 03-25-2005, 12:57 PM
Never thought of that, but you are right. I'd have to be sure the cap was Pontiac specific. Thanks for keeping me from stepping in a hole.
Old 03-25-2005, 01:04 PM
Pontiac Performance Author
The crossfire caps(terrible name for an ign. product,Great name for my 2genF exhaust sys)were marketed bythe Magazine writer David Vizard and some other folks . I used to see them @ swap meets.They definately DID work on Pontiacs.you just had to think a little harder to wire them up!
Old 03-25-2005, 02:27 PM
BVR421's Avatar
BVR421 BVR421 is offline
as, one goes in six... 2 goes in 5...etc
Old 03-25-2005, 07:46 PM
right on
Old 03-25-2005, 10:11 PM
Schurkey Schurkey is offline
http://www.corvettefever.com/techarticles/18459/
Crossfire Manufacturing
116-B N. Mercer Ave.
Sharpsville, PA 16150
(800) 458-3478
Crossfire Industries distributor cap (PN 7148-B)
First guess: Out of business.
Old 03-26-2005, 07:23 AM
PONTIAC DUDE's Avatar
FWIW: If you face #1 on the cap at 12 o'clock facing the firewall. You will have less spark plug wire crossing over each other. Plus easier to R & R as it is at the exact location every time without guessing if it's off one tooth or not.
Old 03-26-2005, 08:12 AM
quicksilver97ta's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">FWIW: If you face #1 on the cap at 12 o'clock facing the firewall. You will have less spark plug wire crossing over each other. </div></BLOCKQUOTE>
Thats a great tip, I never realized that.
I always admired my LT1 cap as it is this criss-cross design also. I did not know anyone made a cap like this for the HEI, does anyone make one for a points distributor?
Old 03-26-2005, 12:18 PM
Half-Inch Stud's Avatar
I have kept 8 - 1 across the firewall* soo long that I thoughts we all did that.
*NOTE: only 2 & 3 are crossing the middle.
After some thoughs here, I think it'sa non-product for Poncho.
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct
Old 03-26-2005, 12:19 PM
Stock Chevy has 1,8,4,6,5,7 crossing the center...they are hosed up.
