Old 04-04-2003, 02:55 PM
birdman birdman is offline
for a 450 -500 h.p. engine,this is a street car see,s a little track time .IS IT WORTH money for a roller chain or is a standard set good enough?
Old 04-04-2003, 03:08 PM
PMD428's Avatar
PMD428 PMD428 is offline
Send a message via Yahoo to PMD428
If you are gonna make a honset 500 hp, why scrimp on a few dollars? Spend a few bucks more and get a good one. I bought a Rollmaster from KRE looks like a nice piece, soon to be installed.
Nothing cuts like a Bridgeport. Still made in the USA!
Stand out in the crowd, drive a Pontiac.
Old 04-04-2003, 04:23 PM
Goatman Goatman is offline
On Vacation
"It is false economy to scrimp on any part that directly effect engine reliability."
Rehrer and Morrison.
Chance favors the prepared mind.
Old 04-04-2003, 04:43 PM
goatman,
then wouldnt a gear set be the best?
Old 04-04-2003, 04:55 PM
On Vacation
I don't know what a gear set is. A gear drive is two or three useless pieces of metal that transmit torsional and vibrational stress from your crank to your cam and back again.
The best chain is a billet roller. That is what I would use on almost any motor.
The only other alternative is a timing belt. A belt is 100% better than a chain, but, at just over $900, it's not for everyone.
Old 04-04-2003, 08:00 PM
tikiklubracing's Avatar
tikiklubracing tikiklubracing is offline
On the 900.00 belt drive. How do they separate the oil from the belt area. I think yer talkin about rubber band drive? New pan or some kind of blockoff?
BIGGERISBETTER-15 yrs in NHRA tech ret. 1977 400 .030, RPM E-Take, Q-jet, 6X, 3650lb. 78 Catalina,14.50's.
NHRA tech.
"Its just a 412, I swear it".
Pontiac tip of the year, quit those damn cigarettes.
Old 04-04-2003, 09:15 PM
Wade Congdon's Avatar
Wade Congdon Wade Congdon is offline
tikiklubracing
See the setup at www.bopengineering.com We are also having a spring sale, $759.99
Wade Congdon
BOP Engineering
Hi-Performance Specialty Parts for Buick, Olds, and Pontiac
Wade Congdon
BOP Engineering
Old 04-04-2003, 09:18 PM
goatman,
if you dont know what a gear set is,(a set of gears) in reference to timing how do you know a timing belt is exactly 100% better.I think they all have some advantage over the other.
Old 04-05-2003, 12:37 AM
birdman, don't f*ck around!
Get a true roller set (Dynagear is an excellent choice) & fogetaboutit!
What G-man is saying is true, like it or not.
SECOND AMENDMENT: AMERICA'S ORIGINAL HOMELAND SECURITY.
I Misus Rash'!
Old 04-05-2003, 08:14 AM
On Vacation
A gear drive is a worthless POS that has no value to anyone, except possibly the hill billy next door that can't afford a blower but likes the "whine" it makes......
A gear set is installed in your rear end.....
Trust me, this is one subject I have done alot of research on.
Old 04-05-2003, 10:42 AM
fasteddy's Avatar
fasteddy fasteddy is offline
The Rollmaster is a nice set. I bought mine from Merrick Motors--around 80.00. Very vesatile for degreeing the cam--9 keyway combos.
fasteddy
fasteddy
Old 04-05-2003, 10:53 AM
Tom Vaught's Avatar
Boost Engineer
"birdman, don't f*ck around!
What G-man is saying is true, like it or not."
Love it when a person asks for advice, then wants
to argue with you when you give them a correct
answer. Almost as if they really just wanted you to agree with them and did not want advice at all.
Rollmaster make one of the best Pontiac chain and
gear set-up but the Dynagear is just as robust but
has less cam timing options. Tom V.
Old 04-05-2003, 11:56 AM
Actually, Rollmaster was what I meant to say.
But somehow Dynagear came out???
Comparing it to other more expensive brands I've used & seen, it's everybit as good & a better value.
Dynagear does makes a good oil pump.
I Misus Rash'!
Old 04-05-2003, 06:37 PM
Never Enough Power Never Enough Power is offline
I would also say use the roller set.All of the sets mentioned above are good sets to use. The gear set up adds additional wear to the motor along with a constant noise .Use only the best brands inside your motor.
Old 04-06-2003, 10:29 AM
thanks for all the info!i will go with the rollmaster.ans tom v. i was not arguing,just when g-man said i dont know what a gear set is when we were discussing timing components seemed rude.my mistake i apoligze!
