Allright!!...finally home after being away for 3 months on job related assignment.
I haven't had a chance to drive either of my T/A's since December and i have the "need for speed". One thing worries me though....I have a 5 gallon container of leaded racing gas that i had planned on using before I left outta town. Never had a chance to use it so before I left, I added some fuel stabilizer to the 5 gls. of gas. Would anyone be hesitant in using the gas after sitting this long? thanks 1973 SD455 T/A 1979 S.E. T/A http://community.webshots.com/album/16587603rOyvmFCiHs
Home of WFO Hyperformance Shaker induction. |
Larry:
Congrats on being back home! Maybe now you'll finally have enough time to finish up the black car. I used to buy race gas by the 55 gallon drum. Usually took me 6-9 months to go through it and it always always ran fine. I'd say as long as you had the container tightly capped it'll be fine, especially since you had the foresight to add the stabilizer to it. Later, Lloyd '72 Formula 400 - soon to be a 455HO, TH400, A/C, etc.; Lucerne Blue with Medium Blue Interior Restoring a '72 GTO 455HO, TH400, A/C, etc.; Sundance Orange with Parchment buckets [This message was edited by Lloyd-TX on March 25, 2003 at 03:23 PM.]
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
Let's go to the track Larry!
Yeah...lets go!!!
First...I gotta get this engine dialed in....its only had break-in time from back in november and now I have to run it with a new Demon carb I bought back in december. torqjunki dave is coming by to lend a hand on the tune. 1973 SD455 T/A 1979 S.E. T/A http://community.webshots.com/album/16587603rOyvmFCiHs
Larry,
The main thing is to keep it sealed and out of the sun...You should have no problem at all.. Good luck at the races.......Dave..1033/stock |
Good deal...been in sealed container and in the garage.
thanks guys 1973 SD455 T/A 1979 S.E. T/A http://community.webshots.com/album/16587603rOyvmFCiHs
Larry, the fuel is fine to use. Brands that are not blended fuels, such as VP will have a longer shelf life. Brands such as Sunoco which is little more reasonable with basically the same effect. They have a shorter shelf life and tend to break down faster. Best stored in a dark colored container out of the sun! Burn it up!!!
Thread Tools | |
Display Modes | |
