I found a set of cal tracs on a 68 f/b I can buy, will they fit my 72 firebird ? Thanks Loren
Loren,
Might be better to post this in the RACE forum.
Home of WFO Hyperformance Shaker induction. |
Ok Larry will do. Thanks Loren
Not without modifying things a bit no.The lower spring plates are quite different in how they mount the shocks,and they locate the axle somewhat differently also.If you are building the rear suspension from the ground up it could be made to work,but it will not just bolt in the same.
