Restoring Rally II Wheels
Hi,
I purchased 4 Rally II wheels that are 15x7" code HW. They are late 70s wheels. Bolt pattern is 5 by 4.75". So they will fit my 1968 GTO. I plan to clean them up, repaint them and buy the trim rings and center caps. My question is which center caps? Will the black plastic caps correct for 68 fit on these wheels? I measured the center of the wheel and it is a little over 2.75"in diameter. Which trim rings are best. Some are 3" deep, others are 2.5" deep. I'm looking for close not concurs perfect. Thanks, Mike
1968 Pontiac GTO 462CID, 4-Speed Manual, 3.55 rear. Aleutian Blue exterior, 219 Teal Blue interior. Chrome bumper, AM & 8-Track and Rally II Wheels |
If you are putting them on a 68 GTO, you would be putting the center caps that have the chrome outer portion with the lucite center cap. For 1968 models with Rally 2, I believe you have the black lucite center cap with the red "PMD" lettering. If you want to have correct caps for the year of the wheels, you need the silver cap with the red pontiac logo engraved in it. Hope this helps.
Regards, Henry 1989 Trans AM GTA Brilliant Red with Dove Grey Interior 5.7 TPI/700R4 3.27 "Aussie" Rear ----- 1972 LeMans with Endura Option Lucerne Blue with Black interior and Black Vinyl Top 400/TH350 (Sold) ----- "Wind in my hair, shifting and drifting, mechanical music, adrenaline surge..." -Rush, "Red Barchetta" |
Hi 72LemansFreak,
Will the 68 style caps with black plastic insert fit on the HW wheels? I remember that somewhere I saw that the later Rally II wheels had a larger center diameter. If so, I may have to use the chrome metal covers. Do you have an old and new Rally II wheel that you could measure for me? Mike
That's a good question. Let me check tonight. I think I have a pair of HW rallys and I'll check the diameter of the center. The wheels on my `72 are repros, so I don't know what to compare them with. I'll be in touch!
Great,
I 'll look forward to hearing from you. Mike
Hey, didn't forget about you, but the weekend got a little complicated. Everything is ok, though. I'll get you the numbers soon. Sit tight and once again, sorry about the delay!
Hi,
Not a problem. I measured the outside diameter of the center of my wheel and it is 2.875". It has the three cut outs evenly spaced in the inside hole. I am assuming that the 1968 center covers will fit. I dropped off the wheels to have them sand blasted this morning. Thanks, Mike
Well, finally measured it and the verdict...
The reporduction (Wheel Vintiques) and late 70s HK rally wheel have the same diameter at the center. I came up with 2 7/8" inches. So...I don't know how much help that is. There is no code on the repro wheels that I could see. If you know where you want to buy the center caps from (Performance years, for example), just ask for the dimensions of the cap! It will be a little less than the measurements we have here. That's normal for these wheels. Good luck and let me know if there is anything else I can do to help.
Thanks.
I got my wheels back from being bead blasted. They are really clean. I plan to paint the insides to protect them from rust and corrosion. Will order a paint and mask kit to do the curbsides. Can't afford the $85 per wheel to have them powder coated. Thanks for checking this out for me. Regards, Mike
Mike, when I did mine I found the mask kit was unnecessary. Instaed, buy some of that green masking tape as it doesn't leave adhesive when you remove it, use a sharp knife to cut the edges, (there is a groove for the knife to stay in) and spray away. One final thought, use a Satin Finish clear coat when you are finished spraying the color coats, I used gloss, and its too shiny.
agreed, here is mine with a rattle can type semi-gloss clear coat. I also taped and knifed these without the mask kit.
70 GTO 400/4SPD-13.97@102.31 |
Hi,
I ordered the trim rings, lug nuts, centers and mask kit yesterday. May not make it to Alabama by Friday, but I will be able to paint the inner sides. I'll get the semi-gloss clear coat to finish them up on the curbside. Thanks for the tip. Mike
Hi,
Today I used a pre-wipe on the inside of the wheels to clean off the dust and debris left on them from the beadblasting. I spray painted the insides with a rust inhibiting gray paint. I also painted the the outsides between the rims. The paint, mask kit, centers and trim rings should arrive tomorrow. I will start painting them on Monday or Tuesday. Should I coat the insides with the clear satin finish paint? So far so good. Mike
Fit of Wheel Centers on Rally II Wheels
Hi,
Got my center caps and did a test fit on my 15x7" wheels. What is the purpose of the three slots in the center hole of the 15x7" wheel? They don't line up with anything on the center caps I bought. Is the center cap only centered by the single screw and the backing plate which goes in the inside of the wheel? See picture below. Thanks, Mike
hi guys
can i ask 2 questions ?how far do you wrap the argent silver around the lip of the rim?to look stock .or do you stop at the lip.also when i paint the laquer and the grey on the back do i clear coat?did they do that in 1970 im restoring my rallies this week and using all the info from you guys. stock 1970 gto eric Last edited by gto19; 11-05-2005 at 12:06 PM. Reason: adding |
Picture of Original Rally II Wheels
Here's a picture of a set of original Rally II wheels and tires from a 71 GTO. These wheels are in original paint, hopefully it will help you with the proper color shade of charcoal gray.
[SIGPIC][/SIGPIC Last edited by 6T5 Cat; 06-15-2021 at 01:05 AM. |
man those are some pretty rims for originals.....i assume same colors for 71 f-body as well......
Yes, same colors for F in 71.
[SIGPIC][/SIGPIC |
6T5 Cat,
That's the charcoal color that I seemed to recall back in the early seventies. Do you have any idea where that correct charcoal gray paint be found today. I'd like to know if there's anything out there now that's even close to that color. Everthing looks like the color on the later Rally Wheels. Thanks, Jim. |
Jim,
Here's the Ditzler mixing formula for the DDL-32947 Charcoal paint: #475 6 units #490 106 units #400 272 units #487 442 units #415 447 units #476 457 units #491 477 units #495 497 units #499 1000 units Bob
[SIGPIC][/SIGPIC |
