power drum brakes??
Mr goats
my sheet looks like your first one, all black. paint thinner cleans them?
Busy lovin Jesus...................... Darrah for President!!! LOL |
phs on that build order
Sorry about that. I read code 511 and assumed power drum. Looking at column 50, it clearly states power steering and disc brakes.
Paint thinner did the trick I used my wifes cookie pan. I let it sit for 5 minutes then did it again. After I was done I put the sheet between two paper towels and let it dry and it came out great as you can see. I did swish the pan a periodically
all done here's a couple pics
The laquer thinner trick will not do anything to get the rust out... I have yet to find anything that will (without destroying the build sheet).
I have experimented EXTENSIVELY with different chemicals, solvents, to try to remove the rust stains from build sheets. Experimentation is what led to my discovery of the fast laquer thinner technique described above. I could not read the build sheet that I found in a 70 Judge Conv and I had an old lemans build sheet that was stained from the tar sound deadener... I tried multiple solvents until I got frustrated and poured cheap laquer thinner over a corner and low and behold the build sheet came clean like it had been through the wash.
Survivors, frameoffs etc http://community.webshots.com/user/firstgenaddict 68 GTO HO 4spd Alpine Blue over Parchment headrest (paused while I restore other people's cars) 70 Judge Conv. RAIII 4spd 4.33 I painted for a friend. http://rides.webshots.com/album/187328041oxAXRI |
dam nice dam nice
I just removed my gas tank today and found another build sheet. Any one else have two?
Bruce Johnson 1970 GTO VOE HUMBLER |
Scott that car came along way since it was in my driveway congratulations brother It's amazing, Paul
Bruce, yours must be a Pontiac plant car? Sheet 1 under the sound deadener and sheet 3 above the gas tank?
Mike, do you know if there is a particular spot on the Oshawa cars were the BS usually is? Thanks Martie
Martie, I haven't heard of any.
Thanks Mike. I just hope I find it when I start tearing her apart.
Maybe the guys at Napa might know. After all, it's part of the good stuff, isn't it? Cheers M. |
Thread Tools | |
Display Modes | |
