Oil additive content lists for you guy's
Here is some info I stole from another site that will help you choose what additive is right for your ride. Look at the amount of zinc in the EOS, I almost fell down. The Valvoline Synpower has been popular as it contains Molly/ZDDP and couldn't find info on Torco MPZ, seems to be a mystery that these oil tech guy's have avoided.
I can't find the exact post but this will get to where I found the info : http://www.bobistheoilguy.com/ Oils zinc content GM EOS ANA Labs code: iron 5 chrome 1 lead 1 copper 0 tin 0 alum 1 nickel 1 silver 0 silicon 10 boron 2 sodium 978 mag 877 calcium 2583 barium 7 phos 6144 zinc 6290 moly 2 titanium 0 vanadium 1 potassium 4 fuel 0.00 vis@100°C 36.3 cSt water 0.05 solids 0.00 glycol pos(?) This the Valvoline Synpower Oil Treatment that comes in the 15oz bottle. Aluminum 0 Chromium 0 Iron 2 Copper 1 Lead 0 Tin 0 Molybdenum 3481 Nickel 0 Manganese 0 Silver 0 Titanium 0 Potassium 0 Boron 1367 Silicon 33 Sodium 60 Calcium 1719 Magnesium 2718 Phosphorus 2109 Zinc 2626 Barium 0 SUS Viscosity @ 210F 188.8 Flashpoint 345F TBN 16.1 STP 4-Cylinder Oil Treatment (Red 15 ounce bottle). FWIW: First number is Butler Cat Labs. Second number is ANA Labs (just analyzed): Elemental Analysis (ppm) Copper: 0 / LT 1 Iron: 1 / 2 Chrome: 0 / 1 Nickel: 0 / LT 1 Titanium: 0 /LT 1 Silver: 0 / LT 1 Lead: 0 / 2 Tin: 1 / 1 Alum: 0 / 1 Silicon: 0 / 1 Sodium: 0 / LT 1 Potassium: 0 / LT 1 Moly: 0 / 2 Boron: 0 / LT 1 Barium: 0 / LT 1 Calcium: 1371 / 621 Magnesium: 5 / 3 Mangan: 0 / Phosphorus: 1814 / 2885 Zinc: 1959 / 2213 LT = less than Viscosity cSt @ 100C: 108.0 / 89.45 Feel free to add to the list if you have any of your favorites Last edited by P@blo; 07-05-2006 at 01:45 AM. |
Do they have numbers on the "real" STP. The one that's not for four cylinders. Mine all come in a lined cardboard tube with a metal pull-top lid and are blue.
Sam
-- Sam Agnew Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it. Ministry - Jesus Built My Hotrod |
I have a couple of the old blue cAns on the shelf but they are 6-7 yrs old. That stuff made Andy Granitelli a very weathy man.
My Daddy bought me a car but all I got was this old Pontiac. |
here is first five CAT analysises:
last two
Also look at the Mobile 1 MX4T motorcycle oil and they don't run cats so the EPA may leave it alone for a wile. |
Good info P@blo!!
BTW, I did a search on the purpose of calcium in motor oil - it is an anti-corrosive (prevents acids from eating up the metals).
"Listen to her why-ee-eye-ine......... Listen to her why-ee-eye-ine" 1965 GTO Post Coupe, Burgundy w/Parchment, 467, Crower 60243, Rhoads V-Max, Ported 5C's, JB Roller Rockers, Original '66 Tripower, Dave's Small-body HEI, RA Exh Manifolds, 2.5" Exh X-pipe w/Super Turbo's and SS Splitters, Tremec TKO 600, 3.91 12-Bolt Posi w/bearing retainers, boxed frame, 4X Discs with hydro-boost, EPAS |
You now see the reason for the popularity of GM's EOS. I will run it in my engine from now on. If I ever wipe another cam lobe, it won't be from a lack of zinc diphosphate!
Alan |
Great info Pablo, thanks for posting that!
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
calcium is there to give your oil strong bones and prevent oiloporosis.
is this thing on? |
Good stuff, any thoughts on Valvoline Racing oil 40wt or 50 wt.
JK
Beers Bikes Babes and Pontiacs Rule!!! 63 Lemans in the 9's race 66 GTO HT Cruiser 06 Triumph Rocket III TURBO! 2300 CC Bad boy KTM 525 Dirt Terrorizer POLARIS 900 RZR 10 GMC SLT Duramax Haul anything anywhere http://www.facebook.com/profile.php?...app_2392950137 |
So what about Mobil 1 or Royal Purple and a flat tappet? add EOS? How much to an oil change?
Mike: lol
Will: Great to hear you could use the lists. JKrull66: I'm not too sure but will see what I can find for you. Skip: EOS 1 ounce/quart = +170ppm ZDDP Synpower: 1 ounce/quart = +45ppm ZDDP STP: 1 ounce/quart = +35ppm ZDDP Myself, I use half a bottle of the EOS per oil change and was using full bottles of STP before I found the oil analysis. Brent Last edited by P@blo; 07-05-2006 at 03:17 AM. |
Although each in their own ratios,with one or the other having more of a specific emphasis on one or the other element. So those two oils (royal purple/torco) should be fine as is,no additives needed IMO. Mobil one seems to be another story entirely. Pablo,if you do a keyword search on BITOG you'll find more info on the torco stuff,not a lot,but some,seeing as how that's where this came from you should have no problem finding it. http://www.bobistheoilguy.com/ |
Heck if you want I'll say the info came from you but makes no difference to me as my intention was to post this to help people who don't know. This gives anyone the ability to look at the VOA's and decide what oil to use and don't need someone to make recommendations based on their preferences. enjoy Last edited by P@blo; 07-03-2006 at 08:43 PM. |
Must be the heat, --take it easy guys, we're all listening and reading, we don't care where you get the info.- we're just darn pleased that you got it for us. Thanks again to the BOTH of you for so much help on this thread.
Bret, me not upset at all and just wanted you to know why I posted this information. Obviously I couldn't have come up with all these oil analyses on my own and should have probably posted the link to where I found it.
I will state it again "the reason I posted the lists was to help someone like me when I first came on to the PY forums and knows nothing about BITOG's site". Or Zinc content in oils for that matter. If I had a problem with others having the info I would have never posted it from the beginning. As for the scattering of information, I only wanted the cream and bet the moderators would get upset if posted the whole Oil Guy's web site but now you got me thinking...lol Please reread my last message Bret as I was only trying to explain why I posted this and really didn't care where the information came from. Nor was I trying to get credit for it. For the life of me I don't really understand what the problem is and was only trying to help you and other members. Yes you have always been a great help and think you may have misread my last post. |
I can remember the old Torco and Kendal GT stickers on all the 60-70s race cars.
Looks like we'll get some Royal Purple this weekend for the black thing. |
kids, i'm pulling this car over!
happy 4th, everyone
is this thing on? |
