Old 09-10-2006, 09:50 PM
fried boloney fried boloney is offline
Default # 11 heads good for anything?
I won an auction on ebay last week,$31.00 for a complete 1970 350 YU engine with extras. The heads were gone thru about 20 or more years ago-new valves,new guides,new seals,new rocker arms,new push rods. Crank was turned,block was hot tanked and cylinders honed.Also got a bell housing and flywheel that has already been surfaced,and a new pressure oplate and throw out bearing,but haven't located the clutch disc yet. Just wondering if these heads were good for anything else?
http://cgi.ebay.com/ebaymotors/ws/eB...BSAA%3AUS%3A11
All this for $31.00 and a tank of gas!
Old 09-10-2006, 10:17 PM
cerino2000's Avatar
cerino2000 cerino2000 is offline
Wanting to know the same thing. I looked at an identical engine yesterday. Fresh, never fired. Guy wanted $100 for it but I just didn't have a use for a 350.
Old 09-10-2006, 11:39 PM
Ron H's Avatar
Ron H Ron H is offline
Small valve low compression heads...
68 Firebird
Are you running with the wind or breaking it?
Old 09-11-2006, 05:43 AM
Kenth's Avatar
Kenth Kenth is offline
Sleeper heads.
Correctly modified as good as any 1968-70 D-port R.A./H.O. heads.
Old 09-11-2006, 11:13 AM
shotgun shotgun is offline
PY Staff -Tech
I run a stock,as in original 60k,on my 400 driver.It runs great,runs outta steam early but for a street car fine.With no tuning went low 14,high 13 should be no problem.
Another thing is they are great cores.If you are building a set,you can build them the way you want,porter has plenty of metal to work with,etc etc.
"resurfacing Pa highways 2 long black strips at a time"
78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z
Best to date 10.00@130.92 mph at 3250#
79 Grand Prix, will be new home for the 440
Goal 9.75z@135mph at 2900#
83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z
Making it the Ultimate Utility Vehicle
Go, tow and show (not so much show, yet)
Old 09-11-2006, 01:11 PM
#11 head is an excellent canidate for port work etc. . Also excellent streetable compression on a 400 . Around 82cc if I remember.
